Question about Casio MSG1010L-1BV Wrist Watch
My broken watch
Please could you help me to find out how i set the time with the hands on the watch its had new batteries and everything else works apart from the time. many thanks donna
  • 944 Answers
Go to this link and type in your module code (4 digit number from the back of the watch) you should get a user manual for your watch; http://world.casio.com/wat/download/en/manual/ hope this helps :)
Posted on May 03, 2007
SOURCE:
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
Chronometer won't start
Not sure this is worded right. A chronometer is watch that has been certified by a Swiss organization to keep time within a set +/- seconds per day in several positions and temperatures.
A chronograph on the other hand is a watch that has push buttons on the side for starting/stopping/resetting a set of hands to mark time elapsed.
If this is truly about a chronometer not starting it is either a broken part or needs cleaning.
If it is about the chronometer not starting most likely if it is a mechanical watch the pusher is stuck or broken or a lever is out of place or bent. If the whole watch does not run then it could be a broken mainspring.
If it is a quartz chronometer it could be a bad battery or if the battery has been changed it is most likely the person that changed the battery has damaged one of the coils and or circuit.
A qualified watchmaker can help with any of these problems.
Hope this helps,
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 28, 2009 | Breitling Watches
I have a Pulsar Analogue & Digital Type Series PP4 model PP4005. I am having trouble setting the analog time. When I rotate the crown, the minute hand and hour hand rotate, but when I set the correct...
It's broken. Mine is doing the same thing. Others online have experienced the same defect. I bought mine from woot.com in July and just gave it to my son for Christmas. Check the Seiko website and send it in for repair. It has a 3 yr warranty.
Nov 23, 2009 | Watches
The hands don't work?
Check out if you have two batteries in your watch - one for LED display, another for analog movement.
If there is only one battery, your watch has a mechanical fault and you will need help of a watchmaker.
Rate, please.
Jul 28, 2009 | Timex Expedition 84601 Wristwatch
SECOND HAND - INVICTA MODEL 2692
Hi Ed,
I have been in the industry for the past 2 years as a watchmaker's assistant. So I'll see if I can help.
The larger second hand you see in this Chronograph model, using it is only available in the Chronograph mode.
How long a battery should last (if I had a dollar for everytime I've heard that one! :)
Well generally a battery should last about 2 years. It all depends on how many functions that watch has, as for a chrono the more you use that function the more the battery power it uses. I have not seen this watch but as it looks to be the 'standard' kind of format of a chronograph, just one battery would surfice.
In regards to 1/10 lap, please take the to a watchmaker as the hands need to be reset, this either can be done manually or can be done by pulling out the crown slightly (please as if you are to forcefull you will pull the crown and stem out) NOT GOOD!. if you pull it out to 'quick date change' where only the date can be changed try pressing one of the pushers and see which sub dial hands move, if that doesn't work try the other pusher.
Again if the above doesn't work, pull the crown out to time set mode (where you can adjust the time) and try the same steps as above. If this fails and it's still off, take it to a watchmaker and he/she will realign the hands for you!
Kind Regards
Shenlun
Jul 12, 2009 | Invicta Dive/Sport - ABYSS ALARM CHRONO...
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Klik radio controlled watch
First, you need to set the hands at midnight. Press the upper button for 3 secs and let go. The hands will start to advance. Watch them, and when you are almost at the position of 00:00:00, press the upper button again briefly and the hands will stop. Then pulse the upper button to finish advancing the second hand to a perfect 00:00:00. Within 10 seconds, press the middle, knurled, button briefly (if you don’t, the watch will just to back to where it was). When you have done this, the watch will start to run (albeit at the wrong time).
Now you need to tell it to set itself from the time signal. Press the upper button and the lowest one *at the same time* for 3 secs and let go. The watch will acknowledge your request by moving the second hand (only) to 12. Leave the watch somewhere it is likely to get good radio reception. In a few minutes, you will see its hands start to move to the correct time, and they will eventually get there and your watch will be working again.
Nov 10, 2007 | Watches
Casio MSG1010L-1BV Wrist Watch Logo
70 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
