Question about Zebra LS3478-ER Cordless Bar Code Reader Barcode Scanner
Intermittent Scans on p370
My p370 will scan several barcodes and then intermittently not even shoot a beam. Then it starts woking correctly again. At other times when I scan my first barcode in a new transaction it shoots a beam but it won"t register it on my screen- flashing that it lost its connection and for me to try again. Is there a service manual available for this scanner? If so, where? Is there anything that is in need of calibration? If so, does it require an o-scope or spectrum analyzer, or just what kind of instrument does it require? All information would be appreciated.
2 Suggested Answers
sgregory1024
  • 3 Answers
SOURCE: Can't get barcodes to scan?
Change your printing speed, it will make it print darker and have better quality of print
Posted on Nov 01, 2013
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
Scanner scans incorrect barcodes to intuit pos on
Needs to be programmed, cal me 847-847-7835 x202
Sep 25, 2013 | Symbol P370 Handheld
I have a newly aquired P370 Symbol Scanner and I cannot get it to automatically "enter" (carriage return) after a barcode is scanned. I have reset the default application, and scanned the Suffix...
One of four reasons for this:
1. The scanner firmware does not support it. Firmware less than rev F does not support the enter- I do not think this is your issue though. You check the firmware revision in the main menu option 4 or scan the barcode out of the Product Reference Guide.
2. Custom firmware on the scanner prevents the enter from being sent. Again check the firmware. If it starts with anything other than an N you should consider sending the device in to Motorola to have it upgraded to standard firmware.
3. The cradle firmware is less than G. If the cradle is less than G it will strip the enter off of the data being sent. If the firmware in your scanner is new enough you can check the revision using menu option 4 in the scanner.
4. An MCL application on the scanner. If you see something other than SKU: on the display the scanner has a custom application on it. The application would have to be modified to add the enter or removed from the device.
Feb 07, 2011 | Symbol P370 Wireless Barcode Scanner
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
Main beam not working. Swap bulb to high beam socket and it works. Sprayed with CRC replaced and started up bike and it worked. Next ride it wasn't working again. Any thoughts?
Can you take apart headlight and measure voltage at low beam socket when bulb is not working? If there is not 12 V nominal at the socket, then the wiring or ZFE is defective. Your bike should still be under warranty??
I have seen one bike that had an intermittent ZFE control module and the high beam was intermittent. Ended up replacing the control module to fix it.
Aug 17, 2010 | 2008 BMW R 1200 R
Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Dec 02, 2009 | Symbol P370 Handheld
Ran scans and came up with intermittant signal
replace the PCV valve, its cheap, causes THAT to happen when dirty, and takes about ten minutes if you are comfortable working under the hood.
Aug 14, 2009 | 1999 Dodge Intrepid
My scanner scans different numbers to what is on
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Mar 07, 2009 | Zebex ZB 2200AM
Intermittent scanner problem
What brand of scanner is it?
Check in your Twain settings if you have auto-edge detection enabled. Sometimes this will mistake content on the page for the edge of the document.
Oct 22, 2007 | Epson Perfection V350 Flatbed Scanner
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Zebra LS3478-ER Cordless Bar Code Reader Barcode Scanner Logo
253 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
