Question about E-Machines T2240 PC Desktop
Increasing memory in e-machine t2240
Anytime I add memory to slot 1, it will not pass post. Everything works in slot 0, up to 1 GB. Nothing works in slot 1. Is there a jumper somewhere or something that needs to be enabled? I can't see a name on the motherboard to go looking on the net.
    Problem Solver:
  • 15 Answers
Hi slcdane 13. One thing with DIMM slots is that, first of all they are color coded there. Im assuming that you have 4 DIMM slots and two of them are one color, and the other two are another color. What that means is that is if One DIMM slot has a RAM module of a certain capacity, then the other DIMM slot of the same color has to contain a RAM module of the same capacity as the first module. Now i am assuming that you have more than two RAM modules and More than 2 DIMM slots. HERE IS AN EASIER EXAMPLE
Lets say you have DIMM slots 1, 2, 3, and 4. Slots 1 and 3 are yellow, and slots 2 and 4 are red. Now lets say you also have 4 Ram modules. 2 of them are each 2 Gigabytes ready, and the other 2 are each 1 Gigabyte ready. Now lets say you take one of the 2 Gigabyte RAM modules and you place it into DIMM slot 1 which is yellow, what this means is that you have to place the other 2 Gigabyte RAM module into the DIMM slot 3 which is also yellow. The remaining 1 Gigabyte modules will have to go into DIMM slots 2 and 4 which are red.
Now do you get it? Same capacity modules have to go into same color slots. Now try it and see.
Posted on Dec 31, 2008
My problum is when i attached ram 1 gb after its system restart and show belue screen and i sure my rem is ok tell me what is problum here????
A) FixYa T.O.S. (Terms of Service) states to NOT post your email address.
The TOS is read when you join.
B) How about posting the MOTHERBOARD manufacturer name, and Model Number?
Also post what ram memory ,manufacturer, and manufacturer code on the ram memory module.
Ram Memory HAS to be in Slot 1. (May state DIMM 1 next to the ram memory slot. Can also be Slot 0, or DIMM 0 )
Slot 1 is the ram memory slot nearest the Processor.
A Processor reads ram memory Slot 1 first.
Do you know;
1) What is the Maximum TOTAL Amount of ram memory, for the motherboard?
2) What is the Maximum Amount for EACH ram memory slot?
3) What type of ram memory is supported?
For an example;
Can it use DDR Sdram at either 333MegaHertz, or 400MHz?
(PC2700 and PC3200, respectively)
4) What ram memory slots have you put ram memory in?
Post back in a Comment.
Feb 18, 2012 | Computers & Internet
What brand of memory ram can I use in a t 2240 ? :) , tnx
The brand doesnt matter, you do need to be concerned with the type you use.
I looked up your computer on emachine's website and determined that you can use 184-pin DDR 266 memory.
search results from newegg (a trusted online retailer in computer/networking hardware):
kingston and pqi are both respectable companies for memory
That being said, I would contact emachine to determine the maximum amount of ram supported by your motherboard:
the page specific to your computer (contact info at bottom):
if you have any questions please let me know.
May 16, 2010 | E-Machines T2240 PC Desktop
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
I have an eMachine T2240 with an Intel Celeron processor 2.20 GHz & 384 MB of RAM.  The only real complaint I have is that this machine runs slow - it is rather aged - and I tend to bump up against my...
Memory: Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. You may purchase here.
This will give you the biggest speed increase.
CPU: I could not find specs for which cpus this motherboard supports. However, I had one of these same machines and succesffuly swapped out the celeron processor for a pentium 4 processor, 2.53 GHz. You should be safe finding a used processor on ebay that's a Pentium 4 2.2 GHz and it should work for you.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | E-Machines T2240 PC Desktop
Asus A7N8X-X (third memory slot)
Sounds like either a bad stick of memory or a bad dimm slot . Have you tried the memory on another motherboard ?
Jul 18, 2008 | ASUS A7V8X Motherboard
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
E-Machines T2240 PC Desktop Logo
131 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
