Question about Dryers
Dryer wont heat after replacing heating element.
My dryer worked great until last night when it quit drying. We figured it was the heating element so we replaced it today. Still no heat. What can we do? We don't have a tester, and we are not sure where the fuses are to check them. Are there pictures anywhere that might help?
  • 5,911 Answers
Find your model number and go to searspartsdirect.com or appliancepartspros.com. Search by model number and you will find diagrams at both sites for your dryer. The heating circuits are usually listed under the "Cabinet" heading. Please take a look at the following link for further dryer advice:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Since you have already indicated that you replaced the heating element, more than likely you have a Thermal Cut-Out (TCO) failure or Hi-Limit Thermostat problem. It is strongly recommended that you replace BOTH of these components at the same. They are commonly sold as a set (more cost effective). Failure to do so may result in premature failure.
If the TCO failed, it is generally for a reason. Most commonly, this is caused by poor dryer ventilation. Improper air flow is the number one cause for component failures in dryers. Not to mention, this can cause a potential fire hazard operating the appliance in a clogged condition. Pay particular attention to the paragraph that discusses proper ventilation and how to check it out. If you cannot remember the last time the ventilation was checked or cleaned, now may be a good time to do so BEFORE you replace any parts. I hope this helps you. Let me know if you require further assistance.
Posted on Jan 04, 2009
  • 351 Answers
Simply get a ohm meter and make sure you can check continuity.
Depending if its a whirlpool, kenmore, sears, roper etc. and which model.
Locate the back of the dryer, unplug the dryer take out the nine-elven 1/4" screws out. you will see about 5-7 different safetys/thermostats, check em all with continuity, along with heating element. If then the all check good carefully plug in dryer turn it on and see if you are getting 220-240 volts. if yes then its the heating element, if no then its mostly likely the timer or one of the safetys are bad.... need more assistance visit. The Surplus Team . We are highly trained staff and will help you FREE.
Posted on Apr 14, 2009
  • 91 Answers
No pictures ,, replace hi limit and safety thermostats ,then you will get heat
Posted on Jan 03, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
heatman101
Aug 22, 2010 | Frigidaire Dryers
WED5321SQ0 dryer doesn't heat or shut off once it's running
well if ran all night you maybe be running a even heat or auto dry cycle. i would first try on a timed dry see if heat then. if does heat (which probably wont) you will be need to replace either the sensor or board that controls the auto dry. or a very small chance that the timers bad. most likely you have a bad heating element. if the machine doesnt heat on the timed dry, then you need to check continuity on the heat fuse(located on heat element housing). if good then check continuity on heat element. i would say you have a bad element or heat fuse.
Aug 01, 2010 | Whirlpool Dryers
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Amana DLE330RAW
send me an email at b4829@yahoo.com and ill give you step by step but dont forget my four boxes here it helps my rating just ref your dryer in the e mail
Mar 28, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
255 people viewed this question
Top Dryers Experts
