Question about Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Paper jam
Okay, I did something none to smart. I had a paper jam so I pulled out the offending paper back towards the front (toward me) instead of pulling on it from the back. Now it won't feed at all instead it makes a noise like it's trying to pick up the paper but after several try's it just gives up and the error light comes on. according to the self test page it says the printer has a "paper jam" inside. I've disassembled it but there is no paper inside.
One bright note is that it will feed manually. :)
  • richtam123 Jan 04, 2009
    Okay after days of thinking about it I narrowed the problem down to the paper tray since it will print by manual feed. Not being a printer tech. I toyed around with it and I finally decided to place a small stack of post-it notes underneath the paper lift mechanism and sure enough it worked! I did a 15 paper print job and it printed smoothly. Now I just need to find out how much a new paper tray costs. ;)
    Thanks again, crichner!!
    Richard
    Master:
  • 461 Answers
Most likely something has broken in the loading gear. Never pull paper against the normal flow, of course, you know that now. Unless you can locate the broken part and replace it, I'm afraid there's not much you can do other than manually feed the paper.
Posted on Dec 31, 2008
  • Curtis Richner Jan 04, 2009
    Be sure the problem with the lift mechanism is isolated to the paper tray and not a part in the printer that interacts with it. Can you see a part functioning on the printer with the tray removed? Of course, you may need to fool the printer into thinking the tray is in place.
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
I have a paper jam in my printer. The paper is
You will have to open the Printer door and pull the paper out if you are lucky it will pull out in one piece if not you will have to get all the pieces out before it will operate again. When pulling out go very easy with it and move your fingers down with the paper to apply force at the closest point to where the paper pulls into printer.
May 13, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
May 27, 2009 | Brother HL-2040 Laser Printer
Papper locked in laser printer.
check the back of printer there is a door to remove jammed papers. open it it should flip down and you can easily remove the paper. but switch off the printer before removing paper.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Sheet of paper is jammed
try opening the top cover and removed residual piece of paper, do not overturn coz this will damaged your mechanism, pull the paper in the paper direction w/c is upwards, in some cases, you can still managed to pull it up towards you but not too much force ensure you took all piece otherwise this will cause some trouble
Oct 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
774 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
