Question about Kenmore 64952 Electric Dryer
Gas Dryer won't Dry
I have an old 110 series kenmore gas dryer, i've cleaned out all the vents and replaced the heat surface ignitor, but no glow. I don't hear the gas valve click on. The motor runs. What else can I check for?
How do I check the coils
  • Kenmore Master
  • 8,220 Answers
Luke Check the flame sensor
Posted on Dec 31, 2008
  • Dan Webster
    Dan Webster Dec 31, 2008
    The heat is regulated with a Klixon mounted next to the blower
    housing near the vent pipe so it can judge the temperature of the air
    coming out of the drum.Right next to it is a melting type fuse. If the
    dryer runs and gets too hot the fuse will melt.But the dryer will still
    run. So if the fuse is good(continuity) and the dryer control(cycle)
    thermostat is also good then you should have power going to the gas
    valve assembly when the machine is running unless the timer is in the
    no heat or wrinkle free/cool down mode. When the gas valve assembly is
    energized the flame sensor
    flame sensor
    mounted outside the burner chamber detects the heat from the
    ignitor. When the heat is very intense then the sensor shuts down the
    igniter
    Igniter
    and that frees up the power so that the coils can be fully
    energised and open the gas gates. The gas comes out and hits the red
    hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes
    or until the control thermostat is satisfied and shuts down power to
    the gas valve assembly. So...
    If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these:
    Gas operator coils
    The coils get hot and quit on these machines when they get a
    little age on them. It is aggrevating because it is a hard to diagnose
    thing. But well worth the 20 bucks.
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
Partial drying
if it's a gas dryer you have bad gas coils,also you might need a clean out,if the air isn't blowing out of the dryer the clothes will not dry,you need to go outside and make sure the flapper is blowing fully open, if it's a long vent line that goes through the wall to reach the outside take the vent line off the back of dryer and blow it out with a leaf blower,then you need to clean out the duct that your lint filter slides into and then vac out the inside of dryer,you should clean it out or have someone come in to clean your dryer out at least once a year so you don't have a fire more so with gas cause you have an open flame in there,if it's gas,run the dryer and see if the ignitor is glowing and lighting the burner,check it again in like a half hour and if the ignitor is lighting the burner you have bad gas coils,if you need more help send the model number located around the opening where you put the clothes in the dryer and let me know if you need anything else
Dec 18, 2009 | Kenmore Dryers
Turn on but no heat
A bad thermal fuse will keep the gas valves from opening , therefor , no heat at any time . There will be no orange glow with a bad ignitor (used to lite the burner ) . Bad coils , the ignitor will glow and when the sensor clicks to cut off the ignitor , the coils should open to let the gas thru . Your dryer has a little peep hole you can remove to see the operation of the gas valve . Also , check the thermal fuse again ( or put the 2 wires togather to check) , disconnect the vent hose from the dryer and dry a load to see if dryes correctly .( Make sure you have good air flow at the dryer )The reason for this is because a dirty or clogged vent , not cleaning the lint screen vent hose kinked , or vent clogged from dryer to outside , will cause the thermal fuse to open .
Jul 29, 2009 | Kenmore 74602 Gas Dryer
Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Jun 29, 2009 | Dryers
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 | Dryers
Kenmore gas dryer 110 70602990
the heat thermostat are open/need to replace
Dec 31, 2007 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer
replace the selonoids
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Kenmore 64952 Electric Dryer Logo
147 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
