Question about Microsoft Xbox 360 Console
My adapter is Wired but my IP address Fails :(
I'm trying to get my Xbox Live running and when i run the tests it says that my Network Adapter it Wired but then it says my IP Address Failed, how do i get it to work?
  • 1 more comment
  • moeee_22 Dec 31, 2008
    its connected to my laptop
  • Anonymous Jan 22, 2009
    i connected it and it is connected but i typed in the ip adress 69.139.117.123 and that didnt work
  • GOODHACK3R May 11, 2010
    FIRST OF ALL, IS YOUR XBOX CONNECTED TO A GATEWAY MODEM OR DIRECTLY TO YOUR MAIN MODEM? JUST ASKING SO I CAN HELP YOU.
    Problem Solver:
  • 6 Answers
I am not sure how to fix it through multi-wired interned but the best way to get connected to the Xbox Live is to give it a direct access to the internet.
Try to look into your manual you got with your Xbox and find how to connect it through other means than direct access.
In the meantime, before you find a way - your best bet is to just take your internet cable that is connected directly to the modem and connect it to the Xbox.
Posted on Dec 31, 2008
Xbox live IP address and gateway dont seem to work
Make sure you are using the xbox networking adapter. Some networking adapters may work on it but if you encountered any problems, xbox tech support won't be able to assist you with some troubleshooting since they don't support any product other than the xbox networking adapter.
  • To test the connection, go to the system area on your xbox live dashboard then go to network settings and select test xbox live connection.
  • If you pass on all test down to NAT then it means you are connected already and you can now enjoy playing online.
  • If you fail on the first part of the test which is Network Adapter or if it says not connected on Wireless Network then you need to perform some steps.
  • Get back to the network setting's area by pressing B on your controller and select restore to factory defaults. Doing this will restore the xbox live settings to default and you need run another test again which may allow you now to pass.
  • If you still fail on wireless network then it means that you need to set your console to wireless mode by going back to Network Settings and selecting the Edit Settings option.
Jul 15, 2014 | Microsoft Xbox Video Game Consoles & Games
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 adapter
you will need to go ito your modem/routers settinngs oen internet browser type 192.168.1.254 then go to wireless then custom services open the box then scroll down to the bottom and select box live the another screen comes up with a box in it open it an select the bottom one it will be your xbox
Dec 27, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live
update your firmware of the router.
the only viable solution.
Dec 19, 2008 | Microsoft Xbox 360 Console
My wireless adapter lights up green but does not connect live
i had to change my ip address and so forth from manual to automatic because all the xbox needed to do was find everything by itself so that it could actually connect to my wireless network.
Dec 07, 2008 | Microsoft Wireless Network Adapter Xbox...
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
Jun 18, 2008 | Microsoft Xbox 360 Console
I cant get wirless xbox live
The 1st question I have is, are you using the official Microsoft wireless adapter (sold seperatly) manufactured by Microsoft? That is the first solution to this issue. If so you must go into your router settings using the home router IP address usually listed on the router unit and setup the router manually to see the microsoft wireless adapter (sold seperatly), try typing this ip address into your browser address line (192.168.1.1) this is usually a generic router IP address to access your router. Your 360 should have a MAC address listed when in the settings and that should be seen by the router as well. Also check your firewall settings to make sure that it allows wireless transmissions. ( My computer usually has to be running for it to see wired & wireless devices properly). I also prefer just running a wired network for connectivity issues with wireless, such as other electronic interferrence from cordless phones & microwaves as I sometimes get with my nintendo Wii.
PAeasop
Apr 20, 2008 | Microsoft Xbox 360 Console
IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Sep 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
