Question about Acer Aspire 1690 Notebook
Do i have bluetooth?
Just wondering if there is bluetooth built-in to this laptop because there is a button for it but when i press it it says no divice. can anyone help?
I have a Acer 1691. It said it had integrated Bluetooth. It should of said It was Bluetooth ready. I also get the no device message. Very misleading !!! Not only do I need a Bluetooth module but I need a cable to plug it into the CN6 plug on the top side of the motherboard. I got lucky and found a pdf file that shows how to take it apart. I looks like I will have to take the bottom section pretty well all the way apart. I will find out for sure when the parts get here. I found the module with the cable on E-bay for around $25. It may take weeks to get here from China. I hope this helps.
Posted on Oct 13, 2008
    Problem Solver:
  • 9 Answers
Hi
Ther's another valid solution
You've to look for this
Acer Laptop Internal Bluetooth 2.0 Module 8pin1.05cm L
on Ebay (www.ebay.com) and connect it into the cn6 connector of the motherboard.
You've to disassemble the keyboard for finding CN6 connector (near keyboard , microphon and touchpad connectors)
Regards
Donald
Posted on Jul 30, 2008
  • Hardisk Jul 31, 2008
    Hi
    I've to modify my previous post
    The right definition is:
    Acer Laptop Internal Bluetooth 2.0 Module 8pin1.25mm
    I Apologize
    Regards
    D.
I had the same question, as the 1690 has a button on the front which is identical to the wireless LAN button but has the bluetooth symbol next to it.
When the button is pressed a message appears on screen stating "No Device"
It appears that a bluetooth dongle may be required, as there is no bluetooth category in device manager!!
Posted on Jan 17, 2008
    Novelist:
    Scholar:
  • 104 Answers
Well the Acer site says that it has built-in bluetooth!(Aspire 1690) If you go to device manager (Right click on my computer, click on manage. Under System Tools in the left pane click on device manager) you should see one of the device categories there as Bluetooth, if you don't see it and see a yellow icon that means you might need to install the bluetooth drivers! If you don't either you might need another component(bluetooth hardware) for the bluetooth to work! hope this was helpful regards, babb
Posted on May 03, 2007
SOURCE:
I have no bluetooth
Do you not have a bluetooth internally installed or is this an error message, and you're pretty sure your laptop says it has bluetooth? If you don't have bluetooth, you can always buy a usb bluetooth dongle and install the software included on the cd that comes with the package then you should be good to go. If your laptop says that it has built-in bluetooth, you probably just have to press a button from your keyboard that says turn your bluetooth on, or if the software isn't installed, you can always install it and it should work.
Sep 23, 2013 | Acer TravelMate 2300 Notebook
I am not sure how to enable my bluetooth. when i press the button with the bluetooth it still doesnt work!!!!!!! please help! my laptop model is Acer ASPIRE 738Z
Hi
When you say when i press the button what button are you pressing
have you slid the bluetooth switch over to the on position on your acer and do you actually have bluetooth on the laptop i have a acer 5630 with the bluetooth switch on the front of the laptop but the laptop dosent even support bluetooth so it crazy having the switch there
Nov 14, 2010 | Acer Aspire 5720-6661 Notebook PC
Hi, I am wondering how to send things from my phone onto my Sony Vaio Laptop via bluetooth. I was wondering how to activate the bluetooth on my Laptop, as I amm struggling to find a solution as to how I...
I use an HP Pavilion laptop so I don't know the exact setup of a Sony Vaio, however, I still believe I can be of some assistance. First, make sure your wireless is turned on. Depending on the year of your computer you may only have to touch the emblem of an antenna, press a button along the rim of your device, or enter the control panel and turn it on through your settings (Start > Control Panel > Network and Internet > Add A Wireless Device to Network). Depending on your version of Windows there may be some variations to this list of options to select. You may have to select Network Sharing Center before selecting Add A Wireless Device to Network.
If the bluetooth is built in you'll be able to search for other bluetooth devices from your computer. If it isn't built in then your system will never find a wireless device to add and you'll have to buy a bluetooth transmitter (Best Buy usually has plenty of good ones). Before you search place your phone in discoverable mode. Once your phone has been found click it and follow the instructions. Due to compatibility requirements this isn't guaranteed to work, your phone and computer stand a chance of not getting along. If this is the case then grab the data transfer cable from your cell phone's packaging (it looks like a charger but it plugs into the USB port instead of the wall) and connect your phone to your laptop with it.
Your computer should install the proper drivers for it automatically if they are available. Once that happens you can click on Computer (My Computer) and find your phone connected as external storage there. If you open it you'll be able to see all the files and folders on your memory card. From this point use the instruction manual that came with your phone so as to avoid removing or rewriting any important items in your phone's programming. This is by FAR much easier though a little less convenient.
I hope this fixes your problem ;)
Oct 16, 2010 | Computers & Internet
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
Just wondering if Pioneer DEH-P4000UB cd player
no it does not have built in bluetooth but you can get a optional bluetooth kit Pioneer CD-BTB200
Jan 02, 2010 | Pioneer DEH-P8500MP CD Player
Bluetooth
There are six sub models included in the model number you have given and according to the acer website none of the specifications indicate that there is wirelss bluetooth built into the laptop. So it appears that it does not.
Oct 04, 2009 | Acer Aspire 5535-5050 Notebook
I press the bluetooth button on my laptop and red cross apears
Acer currently maintain a wide variety of models of notebook computer in the current range, and for any given range of notebooks the onboard options may vary but the case remains constant across the range for each series of notebook. This means that some machines will have case buttons that lack functionality. The most common of these are the Bluetooth and Wireless LAN toggles on the front of many of the cases. You may have the button but the device isn't there, it is only on the more expensive models. Easily fixed by getting a USB Bluetooth adaptor
Aug 09, 2009 | ASUS Z83V Notebook
Acer5920
No there is no bluetooth device inside.
Acer uses same chassis for other laptops with bluetooth, thats why there is bluetooth button.
Apr 20, 2009 | Acer Aspire 5920-6727 Notebook
How do i activate the bluetooth on my laptop
first thing..i want to know which model of you laptop? is there any bluetooth built-in? if there is...try this....
there a bluetooth key button down in your laptop,you switch it on..i think you know the logo of bluetooth...i think so....
if not a key botton,try to press Fn+ bluetooth key in your keyboard.
Jan 04, 2009 | Computers & Internet
Aspire 3683NWXCi bluetooth setup
i dont think it has a built in bluetooth module.you may have to put an external one,like a blutooth dongle.
Oct 22, 2008 | Computers & Internet
Acer Aspire 1690 Notebook Logo
311 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
