Question about Whirlpool LSR5132PQ Top Load Washer
MACHINE NOT COMPLETING WASH CYCLE
MY TOP LOAD MACHINE WILL NOT COMPLETE THE WASH CYCLE. PLEASE ADVISE.
  • 76 Answers
Your problem can be one of a number of things. First, if its stopping in the wash cycle itself i would look at the timer, if it stops when its suppose to spin, i would look at the lid swtch.If its not agitating at all, then replace the coupler.
Posted on Dec 31, 2008
Is not spinning and not completing a full wash cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 23, 2011 | GE WBVH6240F Front Load Washer
The washing machine isn't completing a cycle. It won't spin or drain or complete a sports wash, but ends the cycle after 2 minutes. The washing machine is less than a month old and is definitely not...
Your machine is still under guarantee. Contact the dealer who sold you the machine and make it his problem. Trying to do anything to the machine will void your guarantee.
Jan 25, 2011 | Hotpoint Ultima WF860 Front Load Washer
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Jun 18, 2009 | Kenmore Washing Machines
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Washing Machine that doesn't complete the cycles
I too have a whirlpool top load and it did the same thing. I would put a load in and go back and the clothes were sitting in water. I found that if you close the lid and press gently til you hear a click, it will finish the cycle. So now when I load the washer, I press the lid like that and I have not had the problem since. I hope this helps.
Jan 20, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Spin cycle complete; door refuses to open
check if the water has completely emptied - maybe the filter needs clearing.
otherwise. switch off mains. take top off. feel down the front of the machine to the door lock. you can usually find the peg and operate it with thumb nail but difficult
i assume you have'nt broken the door handle
Sep 18, 2008 | Belling SGE12X Front Load Washer / Dryer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Problem in my washing Machine
If your timer is stopping at the drain cycler (before the rinse) check the LID SWITCH. Most washers will not drain or continue the cycle if this switch is not closed. Open the lid and look for an opening in the housing were the lid sits. try depressing it manually while the timer is at the drain cycle.
Jul 18, 2007 | LG WFT1071TP Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
