Bunn Pour-Omatic Coffeemaker, 10 Cup White
Problem for Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn pour omtic 3 burner
By hornick90 on Dec 31, 2008
bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658)
Coffee maker will not brew
red light comes on and flickers
followed th set up insturctions still nothing, even put a pot of vinegar water through the machine and still nothing.
Solution #1
posted on Feb 12, 2009
Not Rated)
furnoptn
Rank: Guru
Rating: 89%, 68 votes
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Was this helpful?
Yes
No
Popular Solutions for Bunn Pour-Omatic Coffeemaker,
Questions and Unsolved Problems for Bunn Pour-Omatic Coffeemaker,
Do you recommend Bunn Pour-Omatic Coffeemaker, 10 Cup White?
Answer
Answer
how to clean 2008 tim hortons home coffee maker
Answer
Coffee maker only makes 3 to 4 cups and comes out very slow
Answer
I also have been given a Tim Horton's coffee maker (white one) and do not how it works. Can anyone... (More)
Answer
Hi i purchased of ebay the Tim Hortons home brewer by Bunn with no instructions. It is the black and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn Pour-Omatic Coffeemaker,...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
