Question about Dryers
My kenmore electric dryer 70 series don't work
My dryer worked before xmas but we done a load of wash put clothes in dryer and it didn't work we checked the breakers they are good, checked the plugs all good it was working fine can't slove the problem why it won't start trid every thing I think it maybe the button that you push to start the dryer???? modal number 96573800 stock number is 65738
  • Anonymous Dec 31, 2008
    My dryer was working fine, and all of a sudden it just stopped working one day. Breakers and plugs are all fine. I did notice that the bulb went out sometime during the cycle.
  • Dryers Master
  • 8,220 Answers
my kenmore electric dryer 70  series don't work - 95b4403.jpgGood evening Jim, your mission should you accept it will be to remove the nasty blockage which has kill our agent(the fuse)
You will need to get the dust cover off the backside of this wondermous machine and look on the blower housing to the left. Should you be discovered mascarading as a bonified appliance repairdude we will of couse routinely deny any knowledge of this convo. Good luck Jim! Bomp bomp bomp bomp , bomp bomp bomp. tottle loo toottle loo bebbop. Mission imposible Naw. You can do it Jim.
Posted on Dec 31, 2008
Kenmore Dryer 70 series electric-quit heating and timer wont shut
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Mar 14, 2010 | Kenmore 22622 Top Load Washer
I have a Kenmore Series 70 Electric Dryer and I just got done doing some repairs which required pulling the drum. Now when you put a large load of wet clothes it makes a rubbing noise when it is running
when you pulled the drum on this dryer, everything has to go back exzactly as it came out, make sue you set the drum back rt and did not leave any screws out, and or the bracing not right if you changed the belts it will probally be the way you put it back the drum check your work youll find it
Feb 18, 2010 | Dryers
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
80 people viewed this question
Top Dryers Experts
