Question about Microsoft Xbox 360 Console
My vizio 32 inch tv.Objects on the screen blow out to abnormal
Objects on the screen such as the arms on a person blow out to an abnormal size..
Other objects on the screen do the same.
    Problem Solver:
  • 15 Answers
THIS IS AN ERROR IN THE XBOX'S GRAPHICS CALCULATION.
  1. THE EASIEST SOLUTION IS TO EMPTY THE CACHE BY PERFOMING MAINTENANCE ON YOUR STORAGE DEVICE. IF YOU HAVE A HARD DRIVE, GO INTO YOUR DASHBOARD, TO THE MY XBOX TAB( YOU DO HAVE THE NEW XBOX LIVE EXPERIENCE, RIGHT) GO INTO THE MY XBOX TAB THEN SLIDE LEFT TO THE SETTINGS TAB, THEN DOWN TO MEMORY. SELECT MEMORY THEN HIGHLIGHT BUT DONT SELECT YOUR STORAGE DEVICE. THEN PRESS Y FOR DEVICE OPTIONS, THEN ON THE DEVICE OPTIONS SCREEN PRESS THESE BUTTONS IN THIS SEQUENCE X TWICE, LB, RB, X TWICE. YOU SHOULD SEE A WINDOW ASKING IF YOU WANT TO PERFORM MAINTENANCE ON YOUR STORAGE DEVICE. SELECT YES AND THEN IT WILL SAY THAT IT IS PERFOMING MAINTENANCE ON YOUR STORAGE DEVICE. TURN IT OFF THEN TURN IT BACK ON. WHAT THIS DOES IS THAT IT EMPTIES YOUR CACHE, WHERE ALL THESE RANDOM FILES ARE STORED, ALSO YOUR GAME UPDATES ARE STORED IN THIS LOCATION. JUST DELETE IT AND DOWNLOAD THEM AGAIN, FOR CORRUPTED FILES CAN CAUSE THE PROBLEM THAT YOU DEFINE ABOVE. BY THE WAY THIS ALSO WORKS FOR A MEMORY CARD.
  2. IF THAT DIDNT WORK FOR YOU, THEN THAT COULD BE A PHYSICAL PROBLEM ON THE XBOX'S MOTHERBOARD, MAYBE SOMETHING OVERHEATED. IF IT IS STILL UNDER WARRANTY, SEND IT TO MICROSOFT AND GET A NEW BOX. THEY ALSO SEND YOU BACK ONE FREE MONTH OF LIVE WITH THE REPAIRED/ REPLACED XBOX, AND YOU ALSO GET A 3 YEAR WARRANTY WITH YOUR NEW XBOX.
Posted on Dec 31, 2008
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
No picture on tv
I have vizio flat screen tv get sound on it but picture and the screen is blue and my email addersse is Vickie summers @ yahoo .com thank you Vickie .
Feb 19, 2014 | Vizio E321VL 32-inch 720p LCD TV...
Vizio 32 inch replacement screen price
It will cost around 2/3rd of the total cost of the TV.
Apr 29, 2013 | Vizio L32 32 in. LCD HDTV
Can i use a westinghouse screen to replace a vizio screen
Kenneth,
Please re-post in Electronics > Televisions & Video
The only thing I can state, is look at the manufacturer code on the back if the screen, (Westinghouse), and see if it is a replacement for the Vizio's screen.
[This is the Laptop PC category]
Regards,
joecoolvette
Feb 25, 2013 | Vizio 32" Class LCD 720p 60Hz HDTV with...
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
How do you reset a vizio 32 inch tv
i have a 32 inc vizio in it lock on me how do i unlock it
Jun 30, 2009 | Vizio VW32L 32 in. LCD HDTV
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Jun 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
