Question about Gateway 7320GZ Notebook
Unable to turn on my labtop (gateway 7326GZ) computer.
The power button is not engaging. The button appears to be broken. Is there any way other than pushing the power button to turn on my computer?
Can power button be fixed? Please advise.
Frustrated
  • Anonymous Jan 30, 2009
    I had this same problem. I removed the power push button and use a tooth pick to push the on/off switch
I saw this part available really cheap from Computer Parts Outlet.com
Posted on Jan 27, 2009
  • 25 Answers
The real button is under the button you see. You might be able to get the keyboard cover off. If it's not broken broken you could try to reseat it. The part unless you find a cheaper source is 149.00 (which frankly is ridiculous)
Posted on Jan 01, 2009
Why is my cruise not engagine when the button is pushed and sometime it will engage on 2012 ram
Check your vacuum lines. They could be cracked or broken. Cruise control runs off vacuum
Oct 08, 2014 | Computer, Chip, Cruise Control for Dodge...
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
Dryer will not turn on
Is it an electric or gas tumble dryer?
Apr 02, 2012 | Dryers
When I try to install the blade by pushing down and turning the top leaver clockwise, nothing happens. I appears that the leaver is not turning the nut under it. I can't get to the nut to turn it.
there is a very small spring under the mechanism that might have broken. To remove/install the blade you need to lift up on the lever to engage the nut to tighten the spindle until snug and then push the lever down.
Apr 20, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
System battery recharged but system will not power up. Power Button appears lite but in seconds shuts off.
Most likely like any electronic part it may be worn or even broken. I have had to push hard on some computer to get it to startup. So I recommend a new power button chip be installed on the lap top. Or you can try cleaning it or blowing it out. It is a power button issue for sure.
Jan 08, 2011 | Toshiba Satelite 4000CDS Laptop AC Power...
After stalling the bike (1997 vt 750) the headlight isn't on and it won't start. There is no power at the headlight fuse. There is power to the ignition start switch. Do you have any sugestions....
You probably have a broken or dirty starter button. When the button is pushed in halfway it turns off the head light. when it is pushed in the rest of the way it engages the solenoid. Be sure to check the main fuse on the stater solenoid next to the battery that will turn the power off to the entire bike.
Sep 04, 2010 | 1997 Honda VT 750 C2 Shadow
My battery is good and I have 12V to the 30V main fuse, the 10A ingition fuse is good - but when I turn my key I get no poser to the headlight it like it is dead - could it be the ignition switch?
You may have a separate headlight fuse that is blown. You could have a dirty or broken contact base on your ignition switch that is not supplying power to that part of the bike. Or you could have a dirty or broken starter button . The starter button when pushed in half way, turns off the headlight. when it is pushed in all the way it engages the solenoid. If it the button try cleaning it. If that does not work you will have to replace the switch assembly.
Sep 04, 2010 | 2002 Suzuki VL 1500 Intruder LC
93 shadow VLX 600, insert key, turn on ,all lights work except the headlight,(checked bulb-good), checked, starter , starter relay, battery, ignition, on switch, start switch, electrical connections, no...
You either have a broken/disconnected wire or you have a bad starter button. The starter button is a two position switch. Push it in half way and the headlight turns off. Push it in all the way and the solenoid engages the starter. The button is either dirty or broken.
Aug 30, 2010 | 1993 Honda VT 600 C Shadow
We have a Gateway FPD1730 monitor, P/NO 7004665. Manufactured in January 2004. Apparently the spring behind the power button has slipped or broken as the button has dropped back in the hole and cannot be...
THe push button (the button is used to push the switch shaft) is held in place with a plastic finger, it is broken off right now, that is why it dropped back in hole. This is how most of the front panel push buttons are made on most monitors, very cheaply made and design. If the finger is broken in the middle, some time I can fix it by using Silicone RTV to glue it down because the Silicone is flexible. You can try that out.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 24, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
The 4 wheel drive doesn't work in my 89 Ford Bronco
The sound is not coming from the glove compartment, it is coming from the panel behind the drivers seat, that's where the relays and computer are located.
The relays click and apply power to a transfer case motor.
The motor attempts to turn a shaft that engages the front drive shaft.
When the computer thinks the shaft has NOT turned it tries again.
It will try three times then quit, figuring the shaft has not turned.
Get someone to crawl under the vehicle and engage the 4WD (just turn on the ignition- do not start the engine) See if they can hear the motor attempt to turn the shaft, it will make a clicking sound.
If not the connections or the motor may be bad.
I have found the most probable cause is the relays on the control board.
If you are technically adept --
you can remove the small side panel from behind the drivers seat and remove the control board. (remove the power plugs first)
Clean the relay contacts and bend them a little to give them more 'wipe' to keep them clean longer.
Put it back in and turn on the ignition.
Then push the RESET button on the side of the board.
Try the in / out 4WD a couple of times. If it doesn't work turn off the ignition, turn it back on and push the reset button again.
Oct 16, 2008 | 1989 Ford Bronco II
Gateway 7320GZ Notebook Logo
765 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
