Question about Toshiba Satellite M40-S417TD Notebook
Hi there, I have a toshiba satellite m40x, couple of days ago when i went to boot it up it would boot for about a minute then it just stopped and wouldn't turn on at all. the power light flashes green and the battery light flashes orange, so i thought maybe it was the battery so i replaced it but i still have the same problem. if i leave it plugged in overnite it will boot up fine for a minute or two but the lights just won't stop flashing and so the laptop starts to beep the shuts down any ideas?
How do I unlock my scroll lock on my toshiba m40x
Reboot to access Bios, Select F7 to reset all to default. There is a separate option in Bios to unlock scroll lock.
Oct 16, 2012 | Toshiba Satellite M40X-114 M40X-118...
There is a program called memtest x86, if you run simple search for the program memtest you will find it for download. This has to be run at boot time, so most versions are designed to be made as boot disks such as "hirens boot cd". this is what i would run at my shop to test the memory, let it run for a good couple of errors to see if any errors show because of a heat issue. cheers
Aug 30, 2010 | Toshiba Satellite Pro L300 Notebook
I want to change the CPU fan in my Toshiba Satellite M40X
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
Nov 10, 2009 | Toshiba Satellite M40-S417TD Notebook
Laptop wont boot up there is power going through the system
Hi Thomas
try this:
take the battery out and unplug the power cable (charger ). leave it for couple of minutes then push and hold the power button for about 30seconds and let go.
Plug in the charger/power without the battery, then switch on.
if it doesn't work then it could be a problem with the motherboard.
let me know if this worked so we can follow up.
hope this helped
Sep 10, 2009 | Computers & Internet
No boot up on my Toshiba Satellite M40X laptop!
try to clean the memory the bronse pin use dry clothes or pencil eraser then put it back, if encounter same error maybe got problem with flex cable come from motherboard go to lcd panel
Aug 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
try booting without the battery installed.
Apr 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Replace toshiba satellite m40x (z008) 60GB toshiba HD with a Samsung HM160JC 160GB HD
both HDs must be either sata or ide and each one must not have a password lock.
good luck
Dec 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M40-S417TD Notebook Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
