Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Need to add extra bays
I've maxed out my box in terms of hard disks, but would like to add two more SATA disks. Is there someone out there who is selling addon drive bays that I can add into the 5051 case?
  • anja890 Dec 31, 2008
    Thanks for the response. Yes, I've used them all - the 5.25 bays with some salvaged rails, the 3.5 bays, the two at the foot of the case... card reader, floppy drive... they're all there. At this time, the only way I can see to add an additional disk is by adding a new bay, which was the start of this thread.
    I thought of that - leaving drives dangling in the case, I mean - but dismissed that as a really dangerous idea... it seemed too much like I'd be inviting something bad to happen, and knowing Murphy's Law, that'd probably end with me losing a drive's worth of data. :)
    I also did consider changing the case, which seems a terrible shame, because the 5150 case is really a fine case. I've heard too that Dell's mobos are designed for Dell cases - the cases are apparently designed with heat-sinks, etc. specifically for Dell's mobos.
    And changing the case seems like overkill when all i want is a dinky bay to tack on beneath the last bay set, behind the speaker. I wonder how hard it'll be to bend up some sheet metal myself... although, I'd really prefer to get a factory-made bay.
  • 96 Answers
Have you used any spare 5.25 in bays yet?.....the wider ones at the top when the optical drives live? .... you can get 5.25 to 3.5 in side rails to fit to hard drives so they fit in them.
Posted on Dec 31, 2008
  • Derek Fuller
    Derek Fuller Dec 31, 2008
    I think you're going to have to "bodge" it a bit .... i mean the hard drives don't have to be mounted horizontally in bays you can stick them anywhere if you have cables to reach them. Have you considered buying a "Full Tower" case? They have mega space for drives ....
How to diagnose a hard drive
It depends on the OS you use !
On most versions of Windows, right click on the letter of the drive, then click "properties".
In the new window, go to "Tools" tab, and click "Verify now".
Check the the two repair boxes and run the program.
(terms may vary according to version of Windows).
Windows will ask you to reboot to launch the analysis of your disk.
If this does not fix the problem, you'll need to further investigate with more elaborated tools, available free of charge on the net.
Aug 30, 2014 | Hitachi Travelstar 5k750 Hts547564a9e384...
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
I have a 651 Combo-L (MS-6769-010) motherboard and I would like to add in a Barracuda HDD of 160 GB and a Pentium 4 3.2Ghz processor. Any ideas if the board can take these?
The hard drive should be OK, however you did not say if it was IDE or SATA. IDE will work, SATA is not supported.
The CPU you listed is not supported. You may have a look at MSI support:
MSI 651M-Combo CPU Support
Jan 25, 2010 | MSI 651 Combo-L (MS-6769-010) Motherboard
How to Add an Extra Hard Drive Need more storage
From what i've read, it has a SATA hard drive with it. check the PC's Motherboard. If it has an IDE slot with it, then yes you can use it. But if not, you may need to purchase a new SATA HDD to use as an extra storage for your PC. Hope this helps.
Oct 13, 2009 | HP Hewlett Packard Pavilion a1016x PC...
I have just bought a new HP Pavillion M9790A, it comes with one hard disk. I need to install an additional hard disk.. how do i do this please?
First of all make sure what kind of Hard drive you use, It will be either SATA or IDE . To add additional HDD, open computer tower and you will find connectors are available to plugin your new Hard drive else you can follow your computer manufacturer's user guide.
The better option would be to take help from someone who knows how to add new HDD.
Oct 11, 2009 | Computers & Internet
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Nov 29, 2008 | Maxtor Hard Drive
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Jun 17, 2008 | HP Pavilion dv9000z Notebook
Adding a IDE hard drive
It appears that your system has one ide controller for the optical drives, and one sata controller for the hard disk(s).
I recommend installing another SATA drive, the controller in your system is SATA150, so don't spend any extra for a SATA II (300) interface, though if you find a good deal on one, there's no harm in using it, they're backwards compatible to SATA I.  I've been seeing 500gig SATA drives on sale for around 100$.
Oct 19, 2007 | Sony VAIO VGC-RA810G PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
134 people viewed this question
Alun Cox
