Question about RCA VR557 VHS VCR
"SAFE" I moved the VCR from downstairs and set it upstairs. I turned it on and found the code for the remote and turned it to channel 3. Then I inserted a tape. After that, no matter what I do or which button on the front of the VCR I press, the word "SAFE" appears on the display.
  • Mike Testart May 06, 2007
    Sorry, that did not work. I can't even eject the tape. Any button I press brings on "SAFE".
  • 50 Answers
Greetings Spock! Although I worked for an authorized rca service depot for 12 years, and worked on many, I can't remember the solution to your problem, and Thompson Consumer Electronics (RCA/GE) don't even accknowledge they ever sold vcr's..I went to RCA.com and your model comes up as "does not exist"...Anyway...I know I've worked on that model, and if you have the book, check the section about parental lock, or Key lock...your RCA could very well be Samsung inside, and if so press and hold the tv/vcr button for 5 seconds and that will release the key lock feature. It is there so if you set the timer, or just don't want the kids messing with it, you can lock all the key functions, and the unit will do nothing except display "safe" Hope this helps...Live long & prosper!
Posted on May 04, 2007
I have just got a sky+hd 2tb box installed, i have a wireless transmitter and sender that i use to watch sky upstairs in my bedroom, i can get sky upstairs through the wireless scart connector/video sender...
You need to find out if you remote is infrared or radio frequency. If infrared then there are remote extender devices that you can purchase to use your remote. If it is RF, then your search would be the RF remote extender box.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Jul 02, 2014 | Computers & Internet
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Digital channels will not tune
I reconfigured channels a couple of times and they started working. Thanks
Feb 08, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Playing vcr causes new digital tv to lose saved channels
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
Dec 01, 2008 | Vizio L37 Television
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
[2] 811 dishnet receiver
you need to program one remote with a different code, power off or unplug one of the receivers. Go to the other receiver and hit the system info button at the receiver. Now read the remote code at the bottom of screen would be a number between 1 to 15. Program the remote for a different code than what it shows. Push and hold down the sat button on the remote and leave go light will blink, enter code say 14 and the pound key. You will see the light blink 3 times on the remote. Now that code is entered in the remote now with that system info screen up on the tv watch at bottom where code is and hit the record key on remote and you will see it change to 14. All done . now just plug back in your other receiver.
Nov 18, 2007 | Televison & Video
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
RCA VR557 VHS VCR Logo
350 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
