Question about LG WM-2077C Front Load Washer
I have an error message OE come out in the middle of cycle
OE error message
  • 640 Answers
Not draining,,check your drain pump filter...
Posted on Dec 31, 2008
Getting OE error in my LG Tromm washer
Can be down to
kink in drainage hose
water drain pump
or an often overlooked drainage problem ...believ it or not can be a malfunctioning heater in the machine...
hope this points you in the right direction..
Apr 15, 2014 | Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
LG WASHER STOPS BEFORE THE END OF THE CYCLE..OE IS THE ERROR MESSAGE ON THE SCEEN
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Feb 04, 2011 | Dishwashers
We have a LG frount loader and just moved house and now it seems to me stuck middle cycle the message comes up isOE I have checked it is level water is on and the machine runs for 5 mins or so then stops...
Kevin
Jan 15, 2011 | LG WM1814CW Front Load Washer
My LG is 5 years old and cannot complete a cycle error message OE. Can't find my handbook help please.
Hello
Kevin
Nov 08, 2010 | LG Washing Machines
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
LG WM-2077C Front Load Washer Logo
227 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
