Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
  • 72 Answers
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
  • daleydo Apr 05, 2011
    I have the same problem...no leak detected. The appliance is I less than a year old, I have had two new leak kits installed, as well as an entire new computer board...still getting an error 01 code and panel will not function. It has been two months without a dishwasher and eight visits from two separate service providers. I am completely at a loss of what to do and my only solution may be to buy another dishwasher
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Error code 01 after problem has been fixed on electrolux dishwasher
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Electrolux EWDW6505GS error 01
Good Afternoon Friend,
I see that your Electrolux dishwasher, model# EWDW6505GS, is having trouble with an error 01. I suggest resetting your dishwasher. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 20-30 minutes. When the power is restored, run a wash. If your dishwasher is still experiencing an error 01, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 20, 2014 | Electrolux EWDW6505GS Fully Integrated...
Error 1 code now says dry function
If your unit is displaying the ER01, E01, or 01 codes in the display panel you are experiencing a leak concern. The unit has detected a leak somewhere within the unit. This could be within the door seal, the tub basin itself, or in the drain lines/pump. Only a professional can diagnose further for complete repairs.
Dec 25, 2012 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
Error 01 code on led screen and dishwasher does not function.
Errror 01 is a leak detector. In the base of the unit the is a sensor to check for water. If this sensor is activated it will stop the unit from running. The water must be removed, in order for the sensor to reset. It will not reset if it senses water in the base. You can remove the to toe panel, and open the center compartment where the electronic control is mounted. On the top left side there is a series of LEDs that indicate the exact nature of the error code.
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Nov 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
1,171 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
