Question about Gateway 7330GZ Notebook
Screen brightness often flickers
As though there was a loose part or faulty cable.
Has there been an issue with this?
  • Gateway Master
  • 32,281 Answers
Your problem could be a faulty backlighting panel or the power connector for the backlight needs reseating.
There are two connectors on the LCD that are connected to the motherboard, one for the video signal and the other for the backlight power supply, reseat this connector and hopefully your problem will be fixed.
Posted on Dec 31, 2008
1984 yahama virago 1000 that cuts out at 2500rpm as though I shut the key off, starts and runs great till then, why?
Hi, Karen and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com
Idles fine but dies upon throttle
Yamaha 1986 XV1000 Service Manual
OEM parts for Yamaha
Yamaha 1989 XV1000 Owner Manual
Jul 23, 2017 | Yamaha Motorcycles
02 Buell blast died when I hit a large pothole. Lights work. No spark though. New ignition coil, starter module good. Spark plug fairly new (Denson iridium power) kickstand module jumped also.
Hi, Rudy and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Thread No Spark Problem Different Than other threads
Buell Motorcycle Buell Blast starting probs
http://ukbeg.com/downloads/1125/1125electrical.pdf
http://www.manualslib.com/manual/1022673/Buell-Blast-2014.html
Mar 13, 2016 | Buell Motorcycles
Back firing
Hi Anonymous, and the usual suspects are:
1. Loose, corroded, or broken battery cable ends inside the cable harness especially the "NEGATIVE" cable at both ends.
2. A severely drained battery.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2001 Aprilia Pegaso 650
Apr 22, 2014 | 2001 Aprilia Pegaso 650 i.e.
Low speed esitation
DOWNLOAD 2003 Aprilia Rst 1000 Futura
Mar 10, 2014 | 2003 Aprilia RST 1000 Futura
950 V STAR WON'T START EVEN THOUGH NEW BATTERY HAS BEEN INSTALLED AND HAS FUEL
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Frustrated Yamaha Star Won x27 Start
Re My Yahama Star 1100 wont start Road Star Forum Yamaha Road Star
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
YAMAHA XVS950A Owner Manual
Nov 12, 2013 | 2009 Yamaha V Star 950
Backfire carb
Hi Binuya, and the usual suspects are:
Untitled Document
Jul 03, 2013 | 2009 Adly Thunder 125
]98 zx1100 wont idle and backfires when starting
Hi Terrance, and the usual suspects are:
1998 Kawasaki Motorcycle Service Repair Workshop Manuals
Nov 17, 2012 | 1996 kawasaki ZZR 1100
My 99 r1 backfires and reves hi and get hot what do i need to do
Hi Mokell, and the usual suspects are:
1999 Yamaha Motorcycle Service Repair Manuals
May 08, 2012 | 1999 Yamaha YZF-R1
No signal keeps appearing
This message means the monitor is not getting a video signal from the computer.
This could be a loose video cable, a faulty video cable or a faulty video card.
It is possible the monitor is faulty, try connecting it to another computer with a different video cable. This will tell you if the monitor is faulty or not.
Sep 14, 2009 | Acer 22" X223w LCD Monitor
MY MONITOR HAS LOST COLOR.
Sometimes a loose cable will cause this issue. Check to make sure the cable to the monitor is not loose. The images loosing shape may mean there's an entirely different issue, though. I'm not a monitor expert, so not sure where else to proceed.
Nov 17, 2008 | Dell Dimension 8300 PC Desktop
Gateway 7330GZ Notebook Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
