Question about Denon AVR-2807 Receiver
Display gone, no longer functioning
When I turn it on the power blinks green and finally after about 5 seconds is a constant green. The display never comes up and there is no sound passing through it.
It was working fine and I worry I may have fried it.
Anybody know what to do?
  • 1 more comment
  • pennmjd Jan 01, 2009
    My AVR-2807 shut down last night as well. It seems to have over heated. Had both zones running at the time. I get the same green color the switch.
  • brooksknight Jan 02, 2009
    I opened it up and a fuse was blown, not sure if that's the problem but I'm gonna replace that today
  • galacticeyes Apr 09, 2009
    I have the same problem with my standby light flashing green and there is also a relay inside that constantly clicks. Any ideas?
  • 163 Answers
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
Posted on Jan 22, 2009
Try disconnecting all the speakers and then turn unit on. The blinking green is a speaker protection warning. I tried this and the re boot and still will not work. It appears to be a power issue.
Posted on Jan 02, 2009
  • pennmjd Jan 07, 2009
    Did the fuse work. I live near the Denon Center in NJ and dropped mine off today. It is still under the warranty
Look at page 42 of your manual to rest the microprocessor. Power off the unit then hold down the "Pure Direct" and "Night" button simultaneously the press the power button. This will start a unit reset. Victor
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Set clock
Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
May 02, 2014 | 2008 Harley Davidson FXDWG Dyna Wide Glide
Set clock 08 fxdwg
May 02, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
How to reset clock on 2010 softail deluxe?
Apr 26, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
Bad display panel
Might be. http://electronicshelponline.blogspot.com/. Check this link for more detail troubleshooting to Plasma displays, and make it sure.
Jun 13, 2013 | Samsung PN51D550C1F 3D Plasma TV
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Denon AVR-2807 Receiver Logo
543 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
