Question about Panasonic PV-GS80 Mini DV Digital Camcorder
Need to connect my panasonic pv-gs80 to my imac
Looks like i need a dv to firewire cable but cannot seen to find one.  suggestions?
Best buy has brand new ones, or you could surf the web and find a cheaper one at like amazon. Just make sure that the size of the cable matches up with the size of your computer or else it will not be able to plug in.
The problem I have is like the other people, I got the firewire in the port and DV on the camera and my computer just doesn't recongnize it. Where's the solution to this? I have been trying to edit my film for over a year now with troubles with losing wires and now this and stuff. Hope this helps
Posted on Jan 13, 2009
I can not get my iMac, running on OS x 10.8.5 to recognize my Panasonic PV-GS85 camcorder. Tried installing converters but they can't detect a camcorder either. ANy solutions? Any help would be highly...
You will need to capture using a firewire cable.
If you are using a firewire cable and it does not work try another brand of cable as some have a reputation for not handling DV capture.
Al
Oct 18, 2013 | Panasonic PV-GS85 Mini DV Digital...
Where can i buy a data cable for my panasonic pv-gs80 that can config wiht my pc
Ask for IEEE1394 cable also called iLink or firewire.
Beaware that firewire has several types of socket configurations.
In most cases a 4 pin to 6 pin cable will work.
4 pin goes to the camera 6 or 9 pin goes to PC or Mac.
Al
Sep 14, 2013 | Panasonic PV-GS80 Mini DV Digital...
Im having trouble connecting it to my PC. do you need to take the battery out in order to upload videos?
No you don't need to take out the battery.
Tell us what version of windows your running and what connection you are using to hook it to your PC.
ie: USB, FIREWIRE, Ethernet?
Remember to give the thumbs up if this helps.
Feb 26, 2011 | Panasonic PV-GS80 Mini DV Digital...
Searching for driver for NV-GS80 on windows vista platform.
Do you mean a driver for the webcam portion of the camera, or to transfer footage to your computer from the tape? If you mean for footage transfer, then you are in luck, because no driver is needed. You just need your video editing software and it will communicate with the camera over the firewire port and cable.
If you did mean for the webcam feature then you should be able to download it from the support section of panasonic.com
Nov 30, 2010 | Panasonic PV-GS80 Mini DV Digital...
Hi, I have a panasonic pv-gs80 video cam and I would like to save my movies on my e-machine p c. What cables and software do I need? thanks Tim E-Mail timjune@sbcglobal.net
If you don't want to spend a lot of money you could use Corel VideoStudio. As for cables, your camera should have come with a USB 2.0 cable that would connect to the camera and then to the USB port on the PC. Or, if your pc has a firewire port, you could buy that cable to connect for a faster video transfere and capture. Hope this helps.
Aug 16, 2010 | Panasonic PV-GS80 Mini DV Digital...
Panasonic PV-GS35 will not connect to iMac, so can't upload video from mini DV cassettes into iMovie. when I connect with my USB cable, nothing shows up on the iMac saying that the camera or a "N0_NAME"...
So if it's miniDV and you have a firewire cable, it should work. Have you followed this sequence:
If your battery is sufficiently charged to run the cam for an hour's worth of tape, fine, otherwise connect cam to AC power. With cam OFF, connect Firewire cable to Mac and cam. Open iMovie, name your project and create so that the viewer screen comes up. Turn on the cam. At this point, your Mac should, within moments, say "camera connected". Cam needs to be set on "playback" mode for capture. Then click "import" button and your Mac will control the cam.
If you still get a "no camera connected" you have to consider the possibility that either the firewire cable is bad or the firewire port on cam or Mac is bad. If you have more than one firewire port on your Mac, try switching. An Apple store should be able to help you determine if you have a bad cable or cam port, if you take both in to try on their Mac. Hope this gets you on track.
Dec 07, 2009 | Panasonic PV-GS35 Mini DV Digital...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Can i use 4 pins usb cable in Panasonic PV-GS80 MIni Digital Video Camera if not then suggest how many pins of usb cable it required.Waiting for your reply
use only K1HA05CD0014 usb cable provided by company.its use for image downloading (it have5pin at mini usb) use firewire for video capturing (it have 4pin)
Jun 08, 2009 | Panasonic PV-GS80 Mini DV Digital...
Need assistance transferring video to imac
The Panasonic PV-GS12 will transfer video in video record mode and video playback mode using the DV connection (IEEE) Firewire port. PC Mode is restricted to memory card access via USB. If after connecting it in this manner if it does not work try this. With everything connected via firewire and iMovie running. switch the camera to PC mode and the import window should pop up. You may get a comunications error and if you do then switch to playback mode. The import window should stay open and you can control your camera with the iMovie controls.
Jun 01, 2009 | Computers & Internet
Panasonic PV-GS80 Mini DV Digital Camcorder Logo
546 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
