Question about Frigidaire FRS26ZSG
Ice maker wire signal arm will not lock in the ''up'' position
My refrigerator is an 8 yr. old. Frigidaire Gallery Professional Series Side By Side, model FRS26ZSHB3. My ice bin is overflowing. The arm will not lock in the up or OFF position. I took out the ice bin and no ice cubes seem to be blocking the movement of the arm. It seems to move freely, but just won't stay in the up position, like it's not catching. Any suggestions on how to fix?
5 Suggested Answers
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
ginko
  • 19396 Answers
SOURCE: ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
Posted on May 21, 2009
  • 72 Answers
SOURCE: Ice maker arm does not move freely.
there is probably a piece of ice caught under one of the harvest fingers, at this stage of the harvest, the ice arm is engaged and will not move freely until the harvest cycle is complete.
Posted on Jun 15, 2009
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
Not making ice. Water dispenser works and water inlet connection is good. Signal arm is down.
There's nothing left that can be wrong aside from the ice maker. Is there ice in the ice maker now that won't come out? It could either be the motor out or there is a small chance that the ice is stuck and won't let the motor push it out. It would probably cost just as much to replace the ice maker as it would to have someone repair it.
Oct 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The icemaker in my 10 year old side by side Galery series refirigerator doesn't work. How can I turn it off so that it doesn't use water every 15 minutes or so?
lifting the arm on the side of the ice maker will prevent the ice maker from cycling, assuming there is nothing wrong with the ice maker. However, simply turning off the ice maker may not prevent any problems you may be experiencing
Oct 01, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Apr 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker does not make ice
The first thing to check is that the wire bar attached to the ice maker is not locked in the up position.
Next, check that there is water pressure at the back of the refrigerator where the water supply pipe attaches.
If there is plenty of water pressure, the most common cause is a failed solenoid valve that is just past where the supply line connects.
Please report back with what you find, OK?
Aug 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
388 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
