Question about Mitsubishi WS-65807 65" Rear Projection Television
Vertical lines across screen
Hi I get these lines across the screen now. First time it happened doing a convergence reset fixed it. It came back and now wont go away. HELP!! http://www.flickr.com/photos/63217115@N00/
  • pritesh thaker May 04, 2007
    no, hitting the TV doesnt do a thing. I did notice that when i use the DTV input with my HD box the pic is fine. Its only messed up on ant or rgb inputs or s-video.
    the link you might have to copy/paste into browser....this forums seems to ignore the @n00 part of the link.
    THANKS for your input...
  • 71 Answers
First bad link !!! tell me if you get these lines away when you do little hits on the side of the tv , if so that mean you have bad soldering pin and need resoldering regards please don't forget to rate thx
Posted on May 03, 2007
SOURCE:
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Convergence
if the blue lines runs across the screen in the center its a vertical deflection problem it will need to be diagnosed.
Oct 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Can't correct green convergence
need to replace both Convergence ICs number STK392-110 you can het replacements here and they provide free instalation instructions and free on line tech support so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Apr 16, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Vertical Lines
Hi I can try soling your problems
Feb 22, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
