Question about Miele 24 in. G865 Built-in Dishwasher
Drying cycle vent fan is noisy. How can I fix it
When the miele g-865 dishwasher drying cycle vent fan starts up it is very noisy. Also when the dishwasher has stopped and the door is opened, water drains from the vent fan discharge openi g onto the floor. Is there a way to fix this?
  • claire238 Jan 07, 2009
    I have the Miele G 975 Turbothermic, and have exactly the same problem. It sounds like water is getting into the fan mechanism, and when the fan starts up it gurgles until I open the door and drain the water out of the fan opening. It started happening just a couple of months after the warranty expired (typical). I contacted Miele who say they've never heard of the problem, but fo £99 would send someone out to have a look. Needless to say, I'm just living with it, but if anyone knows of a solution I'd love to hear it too.
  • Anonymous Feb 09, 2009
    Identical problem with G865. Fan noisy, and drains water on ground when the door is opened.
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Posted on Jan 05, 2012
    Novelist:
  • 269 Answers
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Posted on Jan 26, 2011
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hi Service, I have a Miele dishwasher model G692 SC Plus which has a problem with the drying fan filling with water during the wash cycle. We open the door at the end of the cycle and water drains out...
Jan 16, 2011 | Miele Dishwashers
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
I have a Miele G 892 Dishwasher and recently the vent for the Turbotronic drying fan has been sticking in open position at the ned of the cycle. Teh result is the next cycle the vent fills with dirty water...
You'll have to take the door panel apart. There's a small drain hose between the turbothermic unit and the detergent dispenser. It's most likely clogged.
Feb 22, 2010 | Miele G880 Dishwasher
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
It leaks from the left side when washing dishes
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dddg
Nov 22, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Drying cycle
To start ensure that heating element and fan are working.
The element can be tested reading ohms with a multimeter.
The fan can be tested evengizing it.
If the fan and element are Ok, then test and eventually replace dryness sensor and timer board.
Dryness sensor can be tested using a multimeter.
Jun 21, 2009 | Miele G848I Dishwasher
Jenn-Air JDB8910 dishwasher moisture coming out left side.
thats a vent fan to help with drying cycle its normal for steam to come out during cycle of drying you might use no heat air dry and turn your jet dry disp up but its a normal part of drying cycle
Feb 11, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Miele 24 in. G865 Built-in Dishwasher Logo
1,410 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
