Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Wont accept faxes
It was working fine, then I moved. It will SEND faxes but will not recieve them. I have switched cords and settings to no avail. I NEED this for work! Please help!!!
  • gbhatti4 Jan 12, 2009
    my fax is not working its says it is accepting but wont print it was working fine before and now it doesn't
  • 461 Answers
Sounds silly, but since you moved have you updated your phone number with those who are faxing? Are you sure the phone line is plugged into the correct jack? Have you tried calling the number yourself? Does it ring? Have you tried manually answering? Do you have DSL- are you using the proper filter??
Posted on Dec 31, 2008
Fax machine isn't able to recieve or send anything
Make sure there is a dial tone on the phone reciever. If there is not check the connections, the cord could be damaged or disconnected. If there is, check the Recieve mode.
If not call Brother support - its free
Mar 31, 2010 | Brother IntelliFAX 2800 Laser Fax
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Intellifax 4100e no modem, cant get dial tone cant send or reciev
We need to start from the wall jack
check with another phone to see if good
on the side of your fax there are 3 jack inlets EXT., PHONE & LINE
you need to go from the wall jack strite to the Line jack nothing els in front of the fax like a modem. ansering machine Est.
If this does not work dubble check jack phone line. phone cord
If not then you have a bad phone board est. cost $150.00 Installed
hope it works for you
Apr 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax wont send only recieve
Please follow the steps given below:
From the control panel, press Copy Mode.
Press Menu.
Press left or right arrow button until Tools appears and then press Check.
Press left or right arrow button until Defaults appears and then press Check.
Press left or right arrow button until Set Defaults appears and then press Check.
Press left or right arrow button until Use Factory appears and press Check again. The factory defaults are now restored.
You will be prompted to set the language, country, date, time and time format, your fax number, and name on the All-In-One.
CAUTION! Reverting to the factory default settings will delete all the printer settings you selected, including Speed Dial and Group Dial numbers.
Next, try sending a fax and let me know the result.
Apr 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Fax machine wont fax out or in.
Check an make sure the phone cord from the wall is plugged into the back of the machine in the port marked "line" and not "phone"
Jun 12, 2008 | Brother Multi-Function Center MFC-240C...
Won't accept faxes
it could be the phone cord its self some require a 4 wire setup while some require a 2 wire set up
also the jack in other room might be setup inappropriately as an out line sometime this happens
May 16, 2008 | Sharp FO 2950M Plain Paper Laser Fax
Brother mfc-7420n fax not recieving faxes, disconnecting
Please double check all cords and besure you are in the right plug.
Mar 27, 2008 | Brother MFC 7420 All-In-One Laser Printer
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
47 people viewed this question
James Cagle
James Cagle
Jim Keysor
