Question about Samsung Digimax S630 Digital Camera
Samsung S630 camera says "low battery" then shuts off
I have a brand new Samsung S630. Was using it fine until yesterday. Now it just gives a green light when I power on, beeps 3 times, black screen and turns off. It has new advanced lithium batteries and sometimes says "low battery" and turns off within seconds. It worked fine with the batteries that came in the box, but those don't work now either. It must not be battery related. Is there a way to reset the camera or something?
  • cubanacook Dec 31, 2008
    Thank you for the suggestion. The weird thing is that it worked fine the with batteries it came with and the ones I put in are of much better quality and right out of the package, so it should at least turn on, I would say. I am stumped.
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Posted on Dec 31, 2008
Can put in new batteries and turn on and it will say batteries are low and shut off
Pls refer to the camera manual. check the battery type. use batteries that is recommended by the manufacturer.
Jan 07, 2011 | Samsung Digimax S630 Digital Camera
My samsung digital camera gives 'low battery' message then shuts off when shutter is pressed, batteries are fine , what can be the problem?
The problem is these cameras are junk, and this seems to be a common problem. Try tapping the camera sharply on both sides. Blowing compressed air into the battery compartment sometimes helps. If tapping the camera sharply doesn't help, use a bigger hammer and whack it harder still. Then go out and buy a camera from a better manufacturer such as Canon or Nikon. With the current low prices it does not pay to struggle with unreliable junk like this camera.
Jan 29, 2010 | Samsung Digimax S630 Digital Camera
You might want to try cleaning the battery contacts in the camera. I usually use a q-tip and rubbing alcohol (not too much, just moisten the tip a little). After doing so, blow in to the camera a couple of times to remove any leftover q-tip fibers and/or alcohol. This happens to me all of the time - the contacts can get a little corrosion/patina on them (even new after manufacturing and storage) that is hardly visible. Good luck.
Jan 11, 2018 | Pentax Optio M30 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Camera not working
Usually when the camera beeps 3 times. It means the battery is low. Then it turns right off. What kind of batteries are you using for your camera?
Dec 27, 2007 | Samsung Digimax S630 Digital Camera
Problem in s630 digital camera
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set- Up 2
- Select Battery Type
Under Battery Type there are two options:
- Alkaline- if you are using non- rechargeable batteries
- NiMH- if you are using rechargeable batteries
Nov 19, 2007 | Samsung Digimax S630 Digital Camera
Wont stay on
You probably don't have the batteries fully charged up. Also you will need to change battery type from alkaline to metal hydride in the "wrench2"(the last icon on the menu) menu. You did get metal hydride rechargeable batteries??? If you got nickel-cadmium rechargeables that might also be your problem with your camera as they don't have enough power.
Aug 28, 2007 | Samsung Digimax S630 Digital Camera
It won't power on
Batteries are too low. Install new alkaline batteries or better yet metal hydride batteries that have been fully charged first.
Jul 23, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
413 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
