Question about E-Machines eMachines Desktop PC
Sound will not come one
I replaced hard drive i may have wires crossed
    Scholar:
  • 96 Answers
Have you installed drivers for the sound card yet? Is there a speaker icon down by the clock on right of taskbar? It's very rare for a soundcard to work on a fresh install of Windows without loading the drivers.
Posted on Dec 31, 2008
    Scholar:
  • 76 Answers
Hi there;
You recently replaced your hard drive and now your sound does not work?
If you computer boots I would guess your hard drive is connected correctly.
I would check your sound component connections.
Could be inside the case at the sound card or as simple as you unplugged the transformer to the speakers. Also check your sound software to make sure it's not muted.
Hope this helps
2000 Pontiac sunfire dash lights coming on and gauges randomly go crazy
Sounds like the connection on the back side of the instrument panel may have come loose.
Nov 13, 2014 | 2000 Pontiac Sunfire
"non-stystem disk or disk error replace and strike any key when ready"
Sounds to me like the hard drive has gone out on it.
If you turn the laptop over you will see a couple panels that can be removed... There will be one that has what looks like a circle type design by it that indicates hard drive access... If you cannot find this icon its not a big deal as the screws are just phillip head screws..
1. Remove panels
2. Verify Hard Drive is seated properly. (Might disconnect then reconnect to make sure)
3. If you can tell the make and model of hard drive this would be a good time to write it down. (I.E. Toshiba, Western Digital, Seagate)
4. Replace panel
Try booting the computer again. If the problem continues then you need to online and do a google search for hard drive diagnostic bootable disc for your hard drive. Most of these programs are universal and can do a cross platform basic checks on hard drives.
To go into more detailed diagnostic you are best to use the software designed by the maker of the hard drive.
1. Download test disc and burn
2. Boot laptop from cd-rom using bootable test disc
3. Run diagnostics.
If it fails then you have a bad hard drive and you will need to replace the drive.
Dec 30, 2013 | HP Compaq 6735s Notebook
160gb cross fire
Try to search the manufacturer's website for information and repair solutions.
May 29, 2013 | SmartDisk Crossfire Desktop (xf160f) 160...
When warm runs rough sets knock sensor code will hardly idle turn front cat cherry red car sat for a year put new gas in it when cold runs great
If the cat is cherry red as you say it is I would check the firing order or timing they may have crossed plug wires this will cause the exhaust manifolds to get red hot and glow let me know if this heled you and good luck.It definitely sound to be timing related or crossed wires.
Feb 09, 2011 | 1999 Mercury Villager
How do i remove my hard drive on my ps3 unit?
If it is an older type PS3 (Phat) on the left hand side of the console there is a small plastic cover. Using a small flat blade screwdriver, carefully prise one end of the cover outwards. There is a small cut-out on one end where the screwdriver goes. When you have this cover removed you will see a blue cross head screw. Remove this screw. You will also see a small wire clip that is attached to the side of the hard drive caddy. Pull this clip outwards. Carefully take hold of the clip and slide the hard drive towards the front of the console. The hard drive will then come out of the side of the console.
If you have a PS3 Slim the procedure is slightly different. On the bottom of the console there is a small flip out cover. Carefully remove this cover and there will be a blue cross head screw. Remove the screw. Now look below the slot where you put your discs. There is another plastic cover. Slide this to the right and remove it. Behind that cover is your hard drive. Flip the metal clip down and pull the hard drive out.
Hope this helps!
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
V-fit herculean cross trainer assembly instructions
assembly of the wires for v-fit herculean cross trainer
Jun 21, 2010 | Body Solid G9S Multi-Station Gym
Blinking check engine light: Misfiring on
My car was misfiring also. My mechanic reccomended using a few bottles of techron fuel injector cleaner, as my car was used alot previously for city driving. Over time, if it is not opened up and run good and hard at speed on the highway, they become clogged and it will misfire. I spent 30 bucks on two bottles, used it on two tanks, and all the hesitation and lights have gone away! It was awesome, hard tyo fiund a good honest mecghanic who will reccomend a 30 dollar fix that isnt even done by them, rather than a few hundred dollars worth of repairs that wont solve your problem.
Aug 01, 2009 | 2000 Audi A4
Sentinel 21'' Security CCTV Clicks when powers on
replace the capacitor when they bulg they will make a clicking sound and make the lights flash on and off as for the visible damage to the hard drive we will cross our fingers.
Jul 29, 2009 | Home Security
Problems with Magic GigaBank 12 GB USB 2.0 Hard Drive?
sounds like bad usb data channels on the drive the far left and far right are powers if im correct the 2 centers are data - and +
(i burned a usb memory stick once with a wrongly wired front usb plug)
Aug 03, 2008 | Magic GigaBank (IUSB12HD10) 12 GB USB 2.0...
URGENT HELP NEEDED (editing a film) G4 0S 10.4
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
