Question about Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum
No motor action when the power is ON
The motor in my Bosch canister vacuum model BSG 81335UC (similar to 81360) suddenly stopped working. The green power indicator is on, but when I push th ON button, nothing happens. There were no signs of any problem with the motor like overheating or smell of burning rubber. Did it the motor protection fuse blow? I would check for and replace it if I knew where it's located. Thanks for you advice.
    Problem Solver:
  • 5 Answers
I saw a moderator say it was the thermal protection fuse for the motor.
Posted on Dec 01, 2014
I have the same problem with mine -- precisely the same model BSG 81335UC. It feels like the power button switch isn't working properly.
Posted on May 14, 2010
My Bosch vacuum won't start
Check the easy things first. Check your circuit breakers. Will a lamp or another appliance work when plugged into the same outlet? If it is plugged in and you wiggle the cord near the plug and near the vacuum will the motor try to run? This would indicate a faulty plug or cord. If the switch, plug or cord is bad, then you need an appliance repairman. Anything else is highly unusual and would probably require a new vacuum. Best of luck.
Sep 22, 2014 | Bosch BSG71310UC Bagged Canister Vacuum
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Power nozzle suddenly stopped working (no power or vibrating). Can these be repaired or should I just buy a new one?
Hello. Check out your reset button located on the top of the power nozzle. It is either black or red. Turn the cleaner on, and while running, push in the reset. Voila! It should be working again. The reset is put in the vac to protect your power nozzle motor. You have a geared belt that is driven by a circuit breaker protected motor. This way, if there is an overload on it, it will shut off, allowing you to clear it and reset it. I hope this helps! Have a good day.
Nov 05, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Where does the hepa filter go
Look for a removeable grille at the top or back of the vac shaped similar to the filtter. The filter is an after filter so it sits beyond the bag
Sep 10, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
Kenmore vac won't shut off, blowing heavy air from vent
For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
Economically, you should just get a new one instead of replacing the whole system guts
Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
May 11, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Where can I buy vacuum bags for my Bosch canister model BSG71 UC
Check out Ebay.com
or
http://cgi.ebay.com/GENUINE-BOSCH-TYPE-G-VACUUM-BAGS_W0QQitemZ190296223025QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190296223025&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Mar 26, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum Logo
224 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
