Question about Kenmore 73952 Gas Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
When first truning on the dryer it work okay (setting on cotton) when back is open you can see heat and flames. after 7 minutes its goes out then you can hear it click to start heating again. You will see the red glow of the starter but no gas flames. I have replaced all thermostats. HElp
  • Kenmore Master
  • 8,220 Answers
Change these:Kenmore 70 gas dryer will heat for 7 minutes then  - 3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Posted on Dec 31, 2008
I have a Kenmore series 70 dryer that runs but does not put out any heat. What part(s) do I need to fix this?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Jun 29, 2011 | Kenmore Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Kenmore 70 series gas dryer does not ignite I chenge the coil still not heating
Check for burnt out glow ignitor. If okay then check thermal fuse and all other thermostats with ohm meter..... all must be in closed position.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
I have a kenmore series 70 dryer (model # 78702894) gas dryer that is running but no heat. How safe is it for me to disconnect the gas line so I can remove the rear panel?
I am having a similar problem (I get heat for about 7 minutes then it stops heating) and just removed the back housing.  I did not have to disconnect the gas line to do this.  Just removed several screws. If your model is constructed differently and the gas line has to be disconnected, make sure you turn the gas off at the shut off switch back at the gas pipe.
Reading on your issue suggests to start by cleaning out all vent hoses to clear any lint obstructions.  I would start there and see if things improved then proceed to removing the back housing to get at the stuff in there.
Jun 25, 2009 | Kenmore Dryers
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 70 Series
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 73952 Gas Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
