Question about Dell Inspiron 1501 Notebook
Why my computer wont charge
My dell laptop wont charge some of the keys dont work
  • trainskee Jan 19, 2009
    my number keys on the top row wont work for my dell inspiron 1501 but the function number keys do work.
    Scholar:
  • 107 Answers
Get a new battery. The life span of a laptop battery is typically only 1-2 years. Check to see if it's still under warranty. If it's not the battery, then it's likely the power converter on the motherboard. Again, check your warranty to see if parts are still covered.
Posted on Jan 06, 2009
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Dell Latitude D830 Laptop Computer PC Notebook Battery wont charge
if the laptop is working with the adaptor connected then the battery is out....
install a new battery....
Nov 18, 2010 | Dell Latitude D830 Laptop Computer PC...
My dell inspiron 6000 wont charge but i dont think the battery is the problem. The powerlead also still has its light on so must be still working. Any suggestions?
Could you check the output voltage of charger with multimeter? If you find output voltage then your charger is OK, Might be some problem with charging cirucit diagram of the laptop. If no output then replace your charger with new one having same specification.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
Jul 12, 2009 | Dell Computers & Internet
My laptop dell c840 charging status apears as idle i purchase 90w adapter and purchase 2new batries but still i am facing problem
It is more than likely the actual plug on the computer that you are plugging the adapter into. Very common issue with Dell portables and if youre still under the service warranty you will get a new computer. I worked for dell tech support for a few years and I dont think theyve changed that policy.
You could try running the diagnostics to see if there is an issue that it can detect, but it's not likely.
Tap the F4 key while the computer is starting and choose the option that says "Run Diagnostics" or "Boot to utility partition".
Jul 11, 2009 | Dell Latitude C840 Notebook
My laptop wont come on (Dell Inspiron 2200)
I have experinced the same issue with the Dell laptops.
My remedy was to purchase a new power supply..(This is the name of the power cord that came with your laptop). You can purchase the power cord from any computer store.
Ask he sales person if you can try the new power cord prior to leaving the store just to make sure this solution works.
I hope this solution works for you as well.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
I didnt understand the solution for the router not working on vista
Try hitting <Fn> + <F2> keys on keyboard. If that doesn;t work click Start > Run > type devmgmt.msc > check device manager for your wireless adapter properties --- is it working properly?
Jun 26, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Power Trouble
How to replace the CMOS battery. Like any battery the computer CMOS battery can fail or lose its charge.
No power or computer does not turn on. No power from the computer can be caused by any of the below possibilities. ... into the laptop you should see a power light or battery charge light.
How to replace the CMOS battery. Cause:. Like any battery the computer CMOS battery can fail or lose its charge. ... Most likely causes are bad power supply or bad motherboard.
Good Luck, Please dont for get to Vote.Thank you.
Dec 19, 2007 | Dell InspironTM 1501 Notebook
Master Reset
That wont restore the function to your n key, it needs a new keyboard. If you dont use it as a portable then you can buy a cheap USB keyboard from your local computer shop and it will work fine. If you really want to restore it then most Dells use the F11 key at the Dell splash screen at boot time
Aug 04, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron 1501 Notebook Logo
47 people viewed this question
Alun Cox
