Question about Panasonic HDC-DX1 DVD Camcorder
Camera will not turn on
I charged the battery installed it and it will not turn on,tried another
battery,same thing ziltch.tried the ac adapter same thing.
Is there a fuse I can replace?
Push the reset button behind the screen????
Posted on Jul 03, 2009
Battery wont charge
Did you try to charge the battery in the camera or on the charger, or both? When both don't work, still it could be the battery, but also the AC adapter, or the USB cable can be faulty.
Try to change one thing at a time. Check if another USB cable helps. If you can use a multimeter measure the voltage coming out of the AC adapter.
Nov 18, 2013 | GE J1470S Digital Camera
Camera does not respond
I see you can't even look on the screen, because you have to start the camera first, before you can switch between taking pictures and viewing. You you not even can see an error displayed on the screen.
Most obvious is the battery, or its connections. The manual says:
"The camera does not work even when batteries are installed."
Insert recharged batteries in the correct direction. "Inserting the battery and the SD/SDHC/SDXC memory card (sold separately)" (p. 13), "Charging the battery and setting up using the supplied CD" (p. 14), "Charging the battery with the supplied USB-AC adapter" (p. 17)
Battery performance may have been reduced temporarily due to low temperature. Take the batteries out of the camera, and warm them by putting them in your pocket for a while.
Then to make sure it is not the battery they advice to connect an external USB-AC adapter.:
An F-3AC USB-AC adapter (available separately) is recommended if the camera will be used for extended periods.
Note that the power cable supplied with the USB-AC adapter is for use exclusively with the USB-AC adapter. Do not use with other devices.
With the adapter, the voltage (and current it can deliver) could be enough to switch on the camera.
If it works, you should take aout the battery and check if the connection point of the battery and in the camera are clean and shiny. If not, please clean them with a dry cloth. Never use a sharp tool to clean electronic contacts. The manual says the battery will live up to 300 charge / discharge cycles. If the camera won't work with the battery and it works with the USB AC adapter, replace the battery.
Nov 16, 2013 | Olympus XZ-1 Digital Camera
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Error E11 with DC4800 camera
This error "may" be associated with a battery problem. Is it possible that the battery is not charging properly.
Other things to try are as follows
1. Connect the camera to the AC adapter or insert onto the Camera Dock and press the Power button on the camera
2.
  • Remove all sources of power (batteries and AC Adapter) from the camera.
  • Remove the Kodak Picture Card or Compactflash Card.
  • Wait a few seconds.
  • Press the Power button twice.
  • Connect the appropriate Kodak AC Adapter to the camera.
NOTE: If you don't have the correct AC adapter, insert a set of fresh or fully charged batteries, according to the User's Guide.
3. The COMPACTFLASH Card could be corrupt. Reformat the card using a card reader or a PCMCIA card adapter in a notebook computer. ***Remember, reformatting erases all information from the card***
4. Try a different CF card as I have seen them fail causling errors.
Jul 01, 2008 | Kodak Cameras
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Panasonic HDC-DX1 DVD Camcorder Logo
728 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
