Search mode on unit indicated by rrapid flashing blue light. only get slow flashing blue light. audio via 3,5mm jack is working.
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
SOURCE: I just purchased a Voyager
You will need to turn off your headset and then press and hold the power
button until the LED starts to flash red/blue, red/blue, it will stay in
this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
