Question about GE 30 in. JGP337 Gas Cooktop
Gas Flow Gas will not flow to burners when knobs are pushed down and rotated each time the cooktop is to be used. Pushing and rotating other knobs will occassionally start gas flow. Once a burner is lit, then gas flows to all other burners when turned on.
  • T. J. Hebert May 21, 2007
    Cooktop is connected to natural gas. Solution not applicable.
    Thanks.
    T.Hebert
    President:
  • 1,462 Answers
Suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
Posted on May 19, 2007
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
Apr 21, 2017 | Gaggenau 11 in. VG 232 Gas Cooktop
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
The igniter spark for all gas rings remains on permanently without pressing down the gas flow knobs. I can see nothing prompted this - I just came into the kitchen one morning to hear the igniter clicking...
This could be a problem with your spark module. its an electronic box either behind or under the cooktop. it sends the spark to the spark tip, which then ignites he gas. So in my opinion i would say it is your spark module.
Feb 02, 2011 | Smeg 23 in. SER34AX1 Gas Cooktop
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
Miele gas cooktop flame shuts off after lighting. If I keep the button down longer to allow more gas to flow to the burner it will stay on.
I had similar problem.Solved by Miele tech by placing rice grain sized wad of paper towel inside knob so it sits slightly higher on the valve shaft.
Oct 05, 2009 | Miele 35 in. KM391G Gas Cooktop
Jenn-air ccg2520 burners will not ignite - no clicking- cn anyone help
check for power by pluging something else in, did it get somthing spilled in it, compressed air blown under knobs removed should doit or just wait for it to dry out are all the burners affected
Jul 01, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
193 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
