Question about Olympus Camedia C-60 Zoom Digital Camera
Problem with camera
Camera appears to operate OK. Green power light adjacent mode control flickers when camera switched off. does not go out at all. It is lit up fully when camera switched on. I have been through the manual, but it does not mention this fault Any assistance would be appreciated. Regards, Tony Islip
  • garrylochh Jun 26, 2008
    I have had the camera for about 4 years with very good results and no problems but recently, for no obvious reason, the green power light does not go out when the slider is closed, it remains on and blinks. The battery loses charge rapidly even with the slider closed. When switched on the camera appears to work normally. I have checked the Olympus manual trouble-shooting section but find no mention of such symptoms.
  • bcomfy Aug 25, 2008
    Same problem - camera works great but if there's a battery in it, the power light is always on. When the lens barrier is closed and monitor is off, the green light just flashes away until the battery is dead. I called Olympus and after consulting with his peers and supervisor and all the reference manuals he had, the customer service rep could not help me. They did send me a new battery :) but I put it in and it still flashes. Did anyone ever get a fix on this, or do I just need to take the battery out of the @#* camera every time I'm not using it? It's a GREAT camera otherwise...
I am having the same exact problem--started Christmas day. The camera seems to lose all user set options as well with each power cycle. For instance I had it set to not beep or make noises when taking pictures, now the default factory settings always make the shutter click sound and such when taking pictures. I am wondering if there is perhaps an internal battery in this camera that is now dead that would remember those settings to cover your regular battery when changing it or if it were drained?
Posted on Dec 26, 2007
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
Screen flickers green on recording
It sounds more like a loose connection on the wires or flex cables that connects the screen to the main circuit board inside the camera.
Jul 04, 2008 | Sony Handycam DCR-DVD300 DVD Camcorder
Getting out of green mode
While in the green auto mode, press cursor-down on the four-way controller. When the capture mode palette appears, use the cursor keys to select the desired mode and then press the OK button.
Full details are in the "Letting the Camera Choose the Optimal Settings" section of the manual (page 62 in my copy).
If you need a copy of the manual, you may download one here.
Feb 15, 2012 | Pentax Optio M20 Digital Camera
How do i remove the green mode from my pentax e40
If you press the green button again it cancels green mode.
If you want to select a different mode press the down arrow on the four way controller when you are in capture mode.
That has icons for different modes like landscape or program mode.
Move to the icon you want by using the 4 way controller then press ok.
The button with a triangle on it that is above the 4 way controller switches between playback and capture modes.
Jan 30, 2010 | Pentax Optio E40 Digital Camera
Display stuck on Play Mode
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-Shot DSC-S50 Digital Camera
My Canon Powershot SD1000 acts like it shuts off when I try to upload pics to my computer. When I plug the usb into the computer and the camera into the usb the Camera will still work perfectly fine...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 12, 2009 | Canon PowerShot SD1000 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not power up
Hi, I had the same problem. One fine day I tried to switch ON the camera but it will never turn ON. Batteries OK and condition of switch OK too. Being a technical person, with the help of some colleagues, I decided to open the camera, assuming that sending it for repair would cost too much. We found a blown smd capacitor marked 4710d. We replaced it with a 47uF capacitor and also a blown link just adjacent to the capacitor. The link resoldered and the camera is working fine now. I must say that even though very complicated, the way this camera is assembled makes it easier to handle.
Aug 16, 2006 | Fuji FinePix S5000 Digital Camera
Olympus Camedia C-60 Zoom Digital Camera Logo
46 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
