Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV made popping sound and then shut off
I have a Mitsubishi DLP TV, and while we were watching it, it suddenly made a loud popping sound and then shut off. When I went to turn it back on, it made weird crunching like sounds. I don't know anything about these kind of TV's so I'm searching around trying to see if I can find a solution.
  • Anonymous Jan 02, 2009
    You need to replace the DLP bulb. It's located behind the left speaker, and is relatively easy to replace. But...it costs about $200, and has to come for Mitsubishi. On the bright side, if you use a credit card to order it, they usually overnight it, reducing your down time. If you bought an extended warranty, this is covered in that. Also, the extended warranty will provide you ONE bulb per year. I've had my WD-52525 for three and a half years now, and have replace the bulb twice, I'll probably be ordering one one here shortly, since it's coming on to about a year since the last one has blown.
    Our first one went very suddenly, two days before the BCS championship game in 2006, and they got us the bulb for game day. Our second we replaced after a blinking orange warning light displayed. Look these up in your owners manual, it describes all common malfunctions in the troubleshooting section.
  • sdisnie2 Jan 02, 2009
    Thanks for everyone's help!
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Posted on Jan 02, 2009
2 Suggested Answers
  • 179 Answers
SOURCE: My DLP TV made a loud popping sound then went off
first. unplug the set for 5 minutes and see if it will reboot. if it does not the you have 2 problems, the chassis is also bad. next open the lamp door cover, it is behind the speaker grill, and behind the lamp door.
take out the lamp and see if it has broken on the inside if it has it needs to be replaced. mits will send you one i believe it is about 100.00 the number is 915P020010. if the lamp looks ok then the color wheel has probably fallen apart.if this is the case the light engine need to be repaired. check out www.tv-techs.com
Posted on Dec 31, 2008
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Heard a loud pop and picture went out. When tv turned on their is still sound but no picture.
I would first remove the lamp and look to see it is intact and not shattered inside.
Dec 02, 2012 | Mitsubishi WD65737 65" DLP TV
I get sound but no picture then the tv shuts off after 5min. It is a Mitsubishi wd-73837
Popping noises are not a good sign; I suspect the sound came from the catastrophic death of an electrolytic capacitor or worse, the death a a power semiconductor.
Open the lower cabinet and using a good light, look for a smaller, separate board with fairly large parts on it; some cylindrical in shape, others block-like that may have copper wire showing.
If, as common, this board is plugged with connectors into other parts of the system, you may be able to swap the failed board out for a replacement bought from a Mitsubishi service center.Expect to pay $100-$150 US if the set is no longer under warranty.
Nov 23, 2011 | Mitsubishi WD-73837 73 in. HDTV
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
