Question about HP Compaq Presario v3000z Notebook
Compaq Presario C304NR STOPS LOADING AT COMPAQ LOGO
Computer worked fine 2 days ago then turned it on and it stopped at the compaq logo. down at bottom left of screen gave choice of boot order or f10 (BIOS). per Hp tecH have reseated memory, re-seated harddrive, drained battery and set bios to default. When i do a hard drive test in bios is says ide device not detected. TecHperson said to send puter in for them to to check. said will cost 298.00. Economy sad don't have that kind of money. Any other help? Running windows vista. CamE with XP but upgrated to vista a year ago- working fine since until 22 nights ago. If I let it sit at logo icon it finally goes to blank screen with blinking curser in upper left but won't go any further. PLease, PLease help
  • sa3id ahozar
    sa3id ahozar Dec 31, 2008
    iwa daryan anakanastanakom ajma3a ali kaysma3
  • whitelace78 Dec 31, 2008
    ANY WAY TO BE SURE? HATE TO SPEND THE MONEY. COULD MAY JUST BE ADAPTORS OR MEMORY
    President:
  • 1,179 Answers
It sounds like the hdd has failed. When you try to boot can you hear the hdd attempting to spin up? Best solution if everything else checked out would be to replace the hdd. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 31, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 31, 2008
    Only way to tell for sure if you have checked everything wlse would be to use a known good compatible hdd & see if it works. Hope this helps.
Compaq Presario MV500
operating system not loading - hard drive may not be working or memory failure. ?
Jul 02, 2013 | Computers & Internet
I have an old Compaq Presario 6420nx (6000) This happened after updating to a XFX 256 graphics AGP card, I installed all drivers and updated bios. After rebooting , no video,mouse or keyboard working. I...
If your computer works fine with an onboard video, it is possible that your motherboard is not getting much power. The agp video card gets power from the motherboard. I suggest using a different power supply.
Jun 01, 2011 | Computers & Internet
I turn on my compaq presario. However, when the microsoft logo appears it stops there and keeps on loading, which means the screen is black. I tried a hard reset and many other things, but it doesn't work....
Hi!
You can try restoring the computer back in time when date isn't yet present using system restore. I suggest you do it in Safe Mode, you can access that by tapping F8 as soon as you turn the PC on( I mean as soon as you press the power button). You will see a bunch of options, please select Safe Mode or Safe Mode with Networking. Then once you booted to Safe Mode, please perform a System Restore. Hope this helps.
Apr 17, 2011 | Compaq Computers & Internet
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
The compaq organize logo wa stock on my screen is
Open cpu cabinet of computer.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect both connection to harddisk,
Reattach ATX power connector.
Sometimes motherbord settings are messup so if you reset settings then it done.
Let me know if you need more assistanse.
Sep 13, 2009 | HP Remanufactured Compaq Presario SR1130NX...
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
How can I restore to factory settings
Compaq/HP: When you first turn on the laptop and see the Compaq/HP logo screen, press the F11 key (you need to do this before the Compaq/HP logo disappears).
pls rate well
May 07, 2009 | HP Compaq Presario V2000 Notebook
Bios says no ide device found (hard frive missing?)
If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
Jan 01, 2009 | HP Compaq Presario v3000z Notebook
Wont pass the compaq screen
problem is with heatsink see the image...
Sep 05, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario v3000z Notebook Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
