Question about Coleman Powermate Powermate 5000W Generator
Makita Generator no power
Hi Carl,
I have a Makita G1300R that stopped producing AC. I've checked it at the output (behind the receptacle panel) and no power there. The Makita tech (on the phone) said it was probably the condenser. Is that the same as the voltage regulator? He also said that there was no easy way to test it as he didn't know the values. I'm just looking for another opinion before ordering one.
Thank you,
Laurence DuBois
  • 169 Answers
Hi Laurence,
Hope you had as good a holiday as I did :-)
Yes the squareish thing in there is a kind of voltage regulator. More correctly, your brushless generator is using this capacitor to regulate output voltage by means of a resonant circuit between a winding on the stator and this part. The short answer is that you more than likely need a new one and because of its particular shape the only realistic source of the new one is Makita.
I disagree with the service tech about the testability of the thing, my Fluke 112 DMM has a capacitance function that would let me tell if your capacitor was shorted ( 0 mfd reading), open (infinate mfd reading), or some value that could be compared to whatever "known" one was applicable. In this case I'd take a loose guess that the reading of a good one is something like 20 - 100 mfd, but that's just a guess.
let me know if the new capacitor doesn't get it,
Posted on Jan 02, 2009
Hi Carl,
I also have a Makita G6100R generator and my problem is slightly different. The generator only puts out 115VAC unloaded (as opposed to the 120VAC nominal rating). When I put it under 1/2 load the voltage sinks to about 103VAC. Is this also a capacitor problem or is this possibly a stator weakening magnetically? Thanks for any insight you can pass along.
Posted on Jul 28, 2009
Honda generator problems
Check the required oem specs for the speed. Make sure it's running at the correct rpm's otherwise if not you'll have a reduction in AC output at the receptacles.
Oct 18, 2017 | Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
McCulloch Generator model FG6000mk 11hp run good until I turn on generator then stop running do you think the generator bad and can it be rebuild ?
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
Jun 12, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have a Honda 3000IS generator that only produces ~50 volts from the 30A receptacle--the other receptacles work fine, as does everything else on the machine. How do I get full voltage out of this...
I would guess that this uses both of the 15 amp breakers to make the 30 amp circuit. Try carefully measuring the voltage at the back of the 30 amp outlet after pulling it out. You may have a bad socket. look at how it's wired behind the panel too and see if there are wires from the other sockets to this one. If so, check all connections between them. If you still can't figure it out, try to get a picture of the panel and the wiring behind it and send it to
Dec 06, 2009 | Honda 3000 Watt Portable Generator
No output from my lincoln ac welder/generator
Check excitor coils, they produce power from the generator head..
Apr 02, 2009 | Welding Tools
No power
Hi Jerry,
The power wires are usually numbered 11 & 22 (one winding) and 33 & 44 (the other winding) Because it makes 190VAC on one side only I'd suspect that the AVR output got burned trying to force the rotor to make voltage it couldn't sense. If I remember correctly the AVR will have wires 11 & 22 connected to it as the sense input, so if that side of the stator is open or shorted, or if the sense wires got broken the AVR will be mased out trying to get the right voltage.
You don't specify which model this is but some of the manuals are available here.
Jan 03, 2009 | Electrical Supplies
Powermate 6250 model pm0545007.01 engine runs no a.c. output
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Power Generator
You have a brushless generator and you've already checked the capacitor that does the voltage regulation (wiring is fine).
The next thing to look at are the diodes, movs, and wires in the rotor.
Oct 30, 2008 | Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
381 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
