Question about Whirlpool Duet GHW9150P Front Load Washer
  • 115 Answers
Something is lodged in your pump
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Comment by jsrock516, posted on Aug 06, 2008 PLEASE NOTE: I failed to mention in my initial symptoms that it IS possible for the drain pump to be running and still NOT drain water. If the pump impeller shears off, or the motor shaft is stripped, the pump will still give the indications that it is running, but will not drain. The usual result would be an error code.
Posted on Dec 31, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from
Why won't my washer spin or drain? - Kenmore 110 Series ...'t+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain -
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Samsung washer has code f 103 can you tell me whats wrong wont spin trys thenstops
I could not find code f103 but u said that it tries to spin but stops. is the drain pump coming on and removing the water from the washer? if there is to much water in the tub clothing it wont spin. check all drain lines to be sure they r clear.
Jun 02, 2014 | Washing Machines
My friends to open a cosplay party, which role should i cosplay for?
Illustrating Aisaka Taiga! ! Super cute playfully sister (Sailor Costumes),
The humanoid computer Angel Heart grumble is also good (Gorgeous Dress)!
Jan 29, 2013 | Video Game Consoles & Games
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Wont spin the water out
check for the DRAIN MOTOR PUMP , located where the DRAIN HOSE is attached to ,it could be clogged,
hpe it helps , AJ
Dec 21, 2009 | Frigidaire GLTR1670A Front Load Washer
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Suds coming out of drain pipe.
you can buy a siphon break to connect the washer drain hose to and put down in the drain that might fix it
Apr 23, 2009 | Washing Machines
Disk wont spin
are you a cute blond? i give you alot of credit, but your going about it wrong. need to know if there is red/blue coming out of the laser. the laser focusing (moving up and down)
3.the spindle height has to be at the correct height for the laser to read the disk (thus spinning it) and the spindle also had had problems with this unit. (you can clean it up )
4. once it spins the disk it has to read the TOC (table of contents)which means it has to move to the inner most part of the cd
5 send me you name address and if your busy friday! lol
Feb 07, 2008 | Sony PlayStation 2 (PS2) Console
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
