Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Crt's on model 51f510
What are the crt's?
are they the guns?
cleaned guns and mirror, adjusted tint to lessen the green, still have a greenish tint to the picture.
guns appeared to still be all in working condition.
what to do?
  • 108 Answers
This could be several things but I would try a greyscale alignment first.
Posted on Jan 08, 2009
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
I have a sony wega and the picyure is clear but has a green tint what could that be
There are several possibilities in that area. The Picture Tube (CRT) is driven by three different video signals. One presents the Red, one the Blue and one Green. All other colors are derived from a mixture of those three colors. The greenish tint could be a sign that the green gun is being over driven or the Red and the Blue are less than adequate to create a normal picture. Sorry to say this but the most common problem that causes that symptom is the emission in the "gun" assembly inside the picture tube is declining with age and hours of operation. Sony Picture tubes are typically good for around 40,000 hours of use. I don't recommend replacing the picture tube. If the set is more than 5 years old I would suggest that you start looking for a new set.
I know this is bad news but I am just telling what I know the most likely scenario that I have seen in 35 years of TV service.
Zashiban
May 29, 2010 | Sony Televison & Video
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
VIdeo Problems with television.
If these are diagonal green lines then one of two things is wrong. You either have a bad video driver transistor for the green on the CRT board or the IC the controls the CRT (jungle IC) is bad. The possibilty of a bad green gun in the CRT is there as well.
May 24, 2008 | Televison & Video
Picture has greenish tint that I can't adjust out
There is a crt drive problem and you can isolate it by unpluggin g the set, removing the green crt socket, in the middle of the three tubes is the green tube by the way, remove one of the other tubes and switching the crt sockets and turn it on. If the set is still greenish, then the green crt is bad and needs replacement, if another color is primart, then it is going to be the green crt drive circuit and is going to need to be serviced. Good Luck
Oct 07, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 27CX22B-501
You did not say whether it is bright, overdriven with retrace lines in it. I've have seen what I just described in Magnavox (common) and Zenith TVs. If you're unit looks like what I just described it could be one of the following problems. The fix for the Magnavox was a 10 ohm safety resistor in the green drive circuit (on CRT board). For the zenith it was the drive transistor on the main circuit board prior to the gun but after the video IC. In either case you will need an O-Scope to signal trace the video circuit to find the culprit. If this is within your expertise go for it, safely of course. If not, get a professional to do it.
May 28, 2006 | Hitachi 27CX22B 27" TV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
