Question about Pioneer VSX-509 Receiver
Subwoofer does not work,i do not have aremotecon trol for recieve
R .do i need a remote control to activate this unit? system is hooked to five speakers
  • 905 Answers
Is this the subwoofer pre out ? and is it amplified after comming out of the reciever sub pre out? also is it turned on in the surround options?
here is the manual for the vsx-d509s http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49515operating_instructions_VSX-D509S_20023151515575700.pdf
Posted on Dec 31, 2008
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a htr 6130 yamaha reciever and when i hook my five channel home theater system it plays for a while then when i turn it up to almost max it turns the unit off completly... how do i hook up my
Hook all the positive and negative wires correctly and read on the speakers and make sure you have them all in the right spot and if that doesnt help its probably because the reciever is maxed out wich is triggering a kill switch wich some recievers have as a safety feature so you dont blow your speakers
Dec 18, 2012 | Yamaha Audio Players & Recorders
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
My Bose 321 series II is not responding to the control remote commands. Everything else does (TV, VCR,etc), but the BOSE receiver does not.
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Jul 16, 2009 | Bose (321GS) System
Hook-up
You should first check the ratings and specification. Then only you can hook up. But from my side plz always use compitable systems
Dec 08, 2007 | Sony SA-WM20 Subwoofer
HOW TO HOOK UP SUBWOOFER
sell your bose system and buy a real home theater surround sound system with a real subwoofer and not a Bose "Bass Module"! Problem Solved!
Dec 07, 2007 | Audio Players & Recorders
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
190 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
