Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear rangemax wpn824 incorrecty or won't detect wireless conn.
I have a rangemax wpn824na v.2
Worked great on my cable connection.
I have moved and now have a wireless broadband (microwave I believe (sattelite looking gizmo pointed at an antenna 6 miles away)). The router either incorrect identifies it as a dynamic IP, or when it does ID it as a static IP, it either won't connect, or throttles it down to under 500kb download speeds, then looses connection.
If cat5 cable coming from dish is connected directly to the back of my PC, it works fine at 3000kb download speeds.
Any ideas??
Thank you
    Sergeant:
  • 366 Answers
Check ISP configuration to match Router settings with your supplier requirements.
Your issue seems related with wrong settings on Router WAN configuration.
Check if DHCP is required on your router or if it has tio be configured as a BRIDGE.
Your ISP should be ready to support you. (Or Netgear)
Posted on Jan 04, 2009
Can I connect non-wireless printer directly to netgear rangemax wpn824?
No you cannot.
To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
Feb 14, 2013 | NetGear RangeMax WPN824 Router
Slow upload speed of NETGEAR RangeMax Wireless-N 150
check if you have wireless WPA key enable, change in every 15 days the password, normaly you have open connection to all neighbours who like to use your internet connection. and you pay the bill.
Jul 15, 2010 | NetGear RangeMax WPN824 Router
I have a netgear wireless router wpn824 and in moving lost the software to be able to connect to another home computer (was on cable at other location) can you purchase just the software
There is a MANUEL way to get the router working. Find somebody that would know the login IP Address of the router (could be 192.168.1.1) and then you can set it up from within your Internet browser. Quite a tricky router to set up though but it can be done
Jul 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Connecting a router to a gateway
Sure, you just need to change the ip address of the Rangemax. Netgear usually uses 192.168.0.1 for their router ip addresses. Plug the ethernet cable from your PC into the Rangemax. Open a web browser and put 192.168.0.1 into the address bar. You should reach the home page of the Rangemax. Change it's ip address to 192.168.0.2 and save.
Run an ethernet cable from one of the four ports in your Netgear gateway to the internet in port on your Rangemax and all should be well.
Jan 15, 2009 | NetGear RangeMax WPN824 Wireless Kit
Can connect through Ethernet but not through Wireless
what is the operating system of your computer and what is the wireless card that it is using?
Jul 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear Firewall
with the router connected, open Internet Explorer and type http://192.168.1.1 after you log in there is a option on the left for firewall and you can turn it off. If it were me I would use the routers firewall over a software firewall though. By the time a software firewall detects a hack, its already in the PC.
May 19, 2008 | NetGear RangeMax WPN824 Wireless Router...
Just want your opinion
Standards
  • IEEE 802.11b, IEEE 802.11g, 2.4 GHz
Physical Specifications
  • Dimensions: 8.8 x 6 x 1.2 in (223 x 153 x 31 mm)
  • Weight: 1.2 lbs (.5 kg)
Performance Advantages
  • When used with RangeMax client adapters, delivers the longest range of any wireless technology on the market up to 500,000 square feet of uninterrupted coverage*
  • Maintains video quality up to 10 times the effective speed when at long distances
  • Improves performance of existing legacy 802.11b and 802.11g wireless devices up to 50%
  • Five 10/100 (1 internet, and 4 LAN) ports equipped with auto-sensing technology
  • Data speed of up to 108 Mbps*
Privacy & Parental Control
  • “Trusted user” controls
  • Time-based usage controls
  • Web site logging
  • Remote management
  • URL content filtering
Security
  • Double Firewall
  • Network Address Translation (NAT) to hide PCs & files from outside users
  • Stateful Packet Inspection (SPI) firewall to deny outside requests for personal information
  • Denial of Service (DoS) attack prevention
  • Intrusion Detection and Prevention (IDS)
  • Wired Equivalent Privacy (WEP) 64-bit,128-bit encryption
  • Wi-Fi Protected Access (WPA, Pre-Shared Key)
  • Wireless Access Control (SSID) to identify authorized wireless network devices
  • Supports 2 VPN pass-through tunnels (IPSec, L2TP, PPTP)
  • Exposed Host (DMZ)
  • MAC address authentication
Warranty
  • NETGEAR 1-year warranty
Package Contents
  • RangeMax Wireless Router (WPN824v2)
  • 12V, 1.0A Power Adapter, localized to country of sale
  • Ethernet Cable
  • Vertical Stand
  • Setup Guide, Setup CD Warranty/Support Information Card
this product seems good, but do you need only wifi o do you want also wimax?
Sergio
Mar 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Netgear rangemax wireless router
The thing you can do is move near the router or get a antenna.
Sep 02, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
