I have COX Cable along the Florida coast. I am unable to get channels 7 and 12 and there's one other lower number channel. The sound is there, it's snowy and has snow noise over the sound of the shows. I've checked the cables lines, but Cox says they are okay. This also affects another TV with standard cable. Thanks for your attention.
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
Ask Cox cable to send u a new listing of the numbers of channels has been changes or u have it already?Sorry no,not really.Read ur universal remote manual,just reprogram the channels numbers that all.
hi, there is an issue with your analog video board, this board converts the lower definition channels to digital, that is why your high def channels are ok
go to menu settings, find add/delete channel or programming or tuning. There should be an option that says "autoprogram" select this option and let the program run thuroughly. It will read and install all available channels. Do make sure tv is set to CATV and that it is NOT set on AIR.
There is a software issue with the cox cable box. You television will only react to the input it receives from the box. Get cox to replace the box and not to tell you it is a problem with the television. Scrivitron
