Question about RCA HD50LPW175 50" HDTV
RCA HD50LPW175 BLINKS 5 TIMES THEN SHUTS OFF-Will not stay on
If anyone has a schematic or service manual to help identify this problem, I would greatly appreciate the input. The television is 2 1/2 years old with a price tag near $2000 and now worth zero unless I can get it operational. The repair service I took it to said I needed to replace a full board that cost $675 not including installation. I believe there must be a better way possibly by replacing capacitors.Any ideas or literature would be appreciated-Bull from NY.
  • 1 more comment
  • Anonymous Jan 17, 2009
    I have an RCA Scenium HD50LPW175. It will go blank, then blinks (5) times, stops and blink again (5) times and eventually comes on. I read my manual and this is expected and they suggest that the door at the rare be properly closed and if it doesn't work, change the bulb. There is also a phone number 1-866-723-6486
  • Anonymous Jan 19, 2009
    RCA Scenium HD50LPW175 (Two years old) I have the same problem except that the set won't come on at all. Replaced bulb and the set still flashes blue light five times. Took it to authorized repair shop and he said it needs the whole inside unit replaced for $400-$600. I cut my losses and told him to keep the damn thing to use for spare parts. I read enough negative things about RCA and this set in particular. Never again will I buy an RCA!! I will buy a Sony, Panasonic or Toshiba LCD set.
  • rachnunez Apr 20, 2009
    Problems with RCA HD61W66 61 in. HDTV Television.
    When i try to power on the light comes on then goes off and does this 2 more times slowly.
    We just moved and i wondered if in the move some thing could have gotten moved around or something.
    The tv is only about 3 years old.
johncaman
  • 201 Answers
SOURCE: I have RCA HD50LPW167 DLP TV with NO Sound and NO
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Posted on Mar 09, 2009
SOURCE: replaced lamp. 5 blinks, does not start
On a very similar model I found there is a ballast board that powers the lamp. The board is likely bad. On my model RCA it is a small board located beneath the fan. Tracing the lamp power cables back would likely allow you to find the board.
Posted on Nov 20, 2007
johnnydiode
  • 647 Answers
SOURCE: Replaced the fuse in RCA R52wm24 and resoldered
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Posted on Oct 06, 2009
Testimonial: "Amazing how you can pinpoint an issue by reading text from someone who has no idea what they are doing! Great job! It was one of the two flimsy cables"
johnnydiode
  • 647 Answers
SOURCE: RCA HD50LPW175 50 in. HDTV Television Problem
If it's agreen wire with a stripe (usually yellow) it is likely a chassis ground (ie center plug of 3 prong electrical cord). The best source for schematics I've found (although they cost) is servivcemanuals.net.
Hope this helps.
Posted on Dec 02, 2009
Testimonial: "i like this information better than take to a repair guy like the other idiots said at least it helps me get started "
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Posted on Apr 10, 2010
We need a manual for an old Philips radiogram to assist in the restoration process please. It was made in Great Britain it is a Philips type AG 10006-15 No: M13395. If anyone can help it would be greatly...
If you know roughly which year it was made you might be able to track it down in Newnes Radio And Television Servicing Books. They list models made in each year. For example 1960-1961 will feature the models from those years, but you might also find it in the next book (1961-1962) or the previous (1959-1960).
I believe they still make them, but the are expensive, however many public libraries have full sets and will allow you to photocopy pages.
Feb 06, 2010 | Electronics - Others
RCA Scenium HDLP50W151YX1
5 Times it is a problem with the lamp.
Either the lamp is gone, or the small pwer board powering the lamp is defective.
Sep 26, 2008 | RCA HD50LPW175 50" HDTV
Sony ICF7600 power amp dead - PCB layout and/or service manual ne
Hello Alex!
You can download the service manual here. Good luck with your repair!
73, KA3O
Dec 30, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
TV color changed to display green only
IF THE GREEN IS ON ALL INPUTS, THEN YOU WILL NEED A DIGITAL AND ANALOG BOARD REPLACEMENT, VERY EXPENSIVE REPAIR, TRY HDMI INPUTS FIRST, THEN COMPONENT AND SO ON
Dec 30, 2009 | Samsung HLT5089S Television
Hope this helps.
Dec 02, 2009 | RCA HD50LPW175 50" HDTV
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
KV-32FS120 Standby Timer blinks nine times
what exact model number of your Sony tv is? I need it to arrange the service manual or schematics.
Aug 12, 2008 | Sony KP-57WS520 57" Rear Projection...
Service manual
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Jul 23, 2008 | Toshiba 57H82 57" Rear Projection...
RCA Tru Flat Model 32F530TYX1
On the inside of the TV it had the name Thomson on a label. I looked for the schematic using RCA / Thomson with the RCA model # and I found the schematic and service manual under Thomson.
Jun 11, 2008 | Televison & Video
RCA HD50LPW175 50" HDTV Logo
1,455 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
