Question about Sony DVP-NS57P
Changing from Region1 to Region free
Can you please share the method used to fix this problem. Is there a code you press on the remote control or do I have to open the unit up?
Thanks you in advance for your insight.
Regards,
Frank
  • IFG1 Jan 16, 2009
    I need to convert my Sony DVP-NS57P from Region 1 to Region free. It's the same problem as listed above. I would appreciate if anyone could share a solution. Many thanks.
5 Suggested Answers
SOURCE: Region Free Panasonic DVD DMR ES-20
DVD Chip UK might help....
http://www.dvdchips.co.uk/
give them a try, regs
Posted on May 25, 2008
SOURCE: programming remote?
on your remote try pressing enter and then the #3 this should program the remote to match the dvd player. It worked for me last night.
Posted on Jun 11, 2008
bluegreenash
  • 661 Answers
SOURCE: Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Posted on Oct 03, 2008
SOURCE: region free method for Sony SLV-D380P
I also need to unlock my Sony SLV-D380P
Posted on Nov 21, 2008
supertech6
  • 513 Answers
SOURCE: Need the remote codes from a bdp s-550 to program another remote
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Posted on Mar 29, 2010
Hi i have a lg bg550 blueray dvd and i have just got a region1 disc is there a unlocking code for this model so i can play region1 and region 2 discs regards **** towner
Could not locate this model but this may help:
Power up the Player, press pause;
Type in 314159 on your Remote Control's Keypad;
This should bring up the Region Selection Screen;
Select the Region (1-6) that you wish to view on your Remote Control's Keypad, sit back, and enjoy ;-)
Two important features with this player.
Firstly, in addition to the first hack listed above, instead of choosing a Region 1 through 6, you can choose to set it Region 0, or region free. This means you will not need to change it every time you put in a disc of differing regions.
Also, if your TV is not capable of both NTSC and PAL playback, you can adjust the format of the DVD player signal by flicking the System Select switch on the rear of the player. Without changing this, the region free hacks listed above may not display correctly if you are using an older TV
To enable VCD, it works for this model as other LG players:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the
characters 01 47 should appear on the display) [If your player is a non UK
model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the
display)
[This number may be different depending on the configuration of your
specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be
displayed).
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
http://www.videohelp.com/dvdhacks/lg-5500n/4153
Jul 25, 2011 | LG BD550 Blu-Ray Player
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Region Free Fix
Follow these steps:
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
I, need a hack for Toshiba DVR-610
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Feb 25, 2009 | Toshiba DVR610 DVD Recorder/VCR
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
Tip
Oritron DVD600 Region Free Fix
Oritron DVD600 DVD Player Region Free Fix
Would you like to unlock your Oritron DVD600 DVD Player to Region Free?
Follow these steps to unlock your Oritron DVD600 DVD Player:
  1. Press the Menu button on your remote control.
  2. Using your remote control, enter the code 1, 6 and 7.
  3. Press the Mute button on your remote control.
  4. Press the Okay button on your remote control.
Your Oritron DVD600 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Changing the region code to multizone
Initially, pls reference this site. Among the the tested method is as extracted below:
  • Press the Menu button on your remote control
  • Press the 5 button on your remote control
  • Press the 7 button on your remote control
  • Press the 3 button on your remote control
  • Press the 8 button on your remote control
  • The currently selected region will be indicated on the onscreen display
  • Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 14, 2008 | Samsung DVD-R155
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
Tip
I hope that helps.
on Apr 25, 2010 | Oritron DVD600 DVD Player
Sony DVP-NS57P Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
