Question about Linksys Wireless-G WRT54G Router
One of the computers on my network cannot access the router suddenly
Have you released and renewed your IP address?
Posted on Dec 31, 2008
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Losing network connection
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
I've had my linksys wireless G router connected and secured for over a year now. All of a sudden this morning my laptop does not sign in to my network name I can sign in to my router but it doesn't have...
Sometimes it happens that the router might got resetted automatically.
You will need to access the router settings page.
change the wireless settings of the router.
change the network name and the security.
This time create a new network name.
Make sure that your computer will be connected to the router with the cable when you change the wireless settings.
then try to connect to the wireless network.
Click Here for more information about the routers and network
Jul 03, 2010 | Linksys Wireless-G Broadband Router
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
My wireless HP prn stopped working suddenly with NetGear router
You need to go into the netgear router settings online with a computer that is attached to the router. You enter this: in the address bar to gain access.You need to know your username and password to gain access to the menu. Then check the wireless settings to see or change the passphrase. Good Luck
Jul 11, 2009 | Computers & Internet
Desktop works (direct to router), laptops cannot connect
first of all make sure that the wireless settings of the router match the settings of your wireless computer.
make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
Aug 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Router Suddenly stopped working...?
try power cycling your network (turn off all of the hardware)
First turn off the computer,
second, the router;
lastly the router (wgr614).
Now, turn the hardware in this order:
  1. Turn on Modem. Wait 2 minutes.
  2. Turn on Router (wgr614). wait 1 minute.
  3. Now turn on the Computer(s).
this should refresh your internet connection. If not, check your routers settings for any wrong info.
to access your router's homepage, type this ( into Internet Explorer.
Aug 11, 2008 | NetGear WGR614 Wireless Router
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
Can't access to another computer on same network
Turn on file and printer sharing for microsoft networks. Find it in network connections. Right click your connection, then select properties. You must also provide at least one file or folder to share before anything will be seen on the networked pc's.
Oct 31, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54G Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
