Question about ViewSonic VA1930WM LCD Monitor
Screen goes to sleep after "no signal" message
While watching an extended streaming video or video file, the monitor screen will go black, show a no signal message, and then the power light at bottom of screen goes to yellow. All the while the audio continues unaffected. Have checked connections and found everything good.
    Master:
  • 461 Answers
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Posted on Dec 31, 2008
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
My screen keeps going black any ideas?
If it's not showing anything and goes to sleep mode, then did you try to select the proper input from the monitor's on-screen menu?
Otherwise I can't help you unless you are more specific - when does it go black, right away or after 10 minutes of watching a movie for example?...
Oct 26, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
I have a HP monitor model f2105, screen is black
Have you recently installed a new video card? If not then you need to because the one you have is broke. If you can plug in another screen to see if that works and if it does then you should re-install the software (if any) that came with the new screen. If you need anything else please let me know.
Mar 22, 2009 | AOC LM729 17" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
ViewSonic VA1930WM LCD Monitor Logo
368 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
