Question about Motorola Mobility RAZR V3
How to i master clear a verizon razor V3m phone?
How do i do a master clear on motorola razor V3m phone? There is no initial setup option in the menu also there is no master clear or master reset option HELP
I just got a moterola razor V3 and i need to do a factory reset THERE IS NO OPTION IN SETTINGS WHAT DO I DO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! this is seriously pissing me off
Posted on Oct 30, 2009
    Brigadier General:
  • 7,752 Answers
What you should do is take the phone to a mobile store then and have them reset it for you
Posted on Dec 31, 2008
How to master reset a verizon v3m razor
to perform a master reset, please contact the manufacturer for further assistance. their website might tell you how to do it if not their 800 number is listed on nthe site
Jun 16, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How do I erase all contacts on my razor phone?
simple way restore factory setting or do software restore your all contact erase automatic and you phone also works fast becouse of software restore its also helpful for mobile becouse it refers your mobile
Oct 29, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My motorola razor V3m is frozen and will not do anything. pls help me
the only cure other than flashing it is to take battery out. lay it up for 4-5 days and when you put battery back in. if it working you need to do a master clear in phone.try to find an old sim card to do this because you will lose all contacts if you dont. make sure contacts are all stored to sim then go into settings then initial setup go up one to master clear it will ask for security code enter 6-0's (000000). it will say this will delete this,this,this and this do you want to continue (you select yes) and wait phone will reboot itself and should work fine after that.
Sep 20, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Trying to delete active line on razor v3m?
to fix the 'security code' problem on a Razr V3c, TRY the following. It WORKED forme when default "000000" failed to work.Settings > Initial Setup > Master Reset; To reset alloptions, you need to enter the Security Code 183729. After that you can then reset your new security code to whatever you want, including back to default "000000".
Jul 11, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Delete my number from0old phone
Go to menu/setings/initial setup/master clear/enter 6 zero press ok/ good day.
Feb 01, 2009 | Motorola Mobility RAZR V3
Razor shuts off by itself
your probly right.....its either corupt software of a battery issue....try the obvious first (remove and reinsert the battery if you havent already)....if that fails, try the master reset.
MENU > SETTINGS > INITIAL SETUP > MASTER RESET
**default code is 000000 (6 zeros)**
if THAT doesnt work, try a different battery. you can pick them up cheap if you dont have one lying around from www.amazon.com or www.shopmotorola.com
if thats not an option, try a master clear. if you dont want to buy anything, i would try this first. the master reset just sets everthing back to manufacturers default.....the clear DOES. you will LOOSE EVERYTHING INSTALLED ON THE PHONE MEMORY.
to do this, go to MENU > SETTINGS > INITIAL SETUP > MASTER CLEAR
**again, default code is 000000 (6 zeros)**
good luck :)
Jan 26, 2009 | Motorola Mobility RAZR V3
Motorola MOTORAZR² V9m
Go to Menu/settings/initial setup/master reset enter 6 zero ok.
Similar Menu/setting/initial setup/master clear enter 6 zero ok.
Before to do that function,copy all phone book to simcard.
Dec 26, 2008 | Verizon Communications Motorola MOTORAZR2...
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Moto Razr v3m Alarm Clock doesn't work in 'Alarm Only' Mode
is your audio or mp3's sounds normal? if not you have to bring it to the center and clean the connections or replace u'r buzzer., and if u'r audio's working fine and only the alarms are not, try to do this, go to menu, settings, initial set up,master clear ,code ( 000000 ) then w8 and fones boot, then go again to menu, settings, initial set up, master clear code ( 000000 ) fone boots.,, and now try to do u'r thing's ,.. let me know
Apr 28, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
2,568 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
