Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sony KF50we610 blue dots and blue cloud
I just had the bulb replaced om my sony. Now I have tine blue dots on the screen and a light blue cloud across the bottom of the screen How do i repair this
  • 1 more comment
  • cahartm Nov 04, 2007
    I recently replaced the XL-2100 lamp in my KF-42WE610 lcd rear projection set and I also have the blue cloud (or blue misshapen band) across a large portion of the bottom of the screen. I did not have this issue with the old one and this new lamp is a direct replacement recommendation & purchase from Sony's site, "Sony Style" website. I've removed the lamp and reseated repeatedly; I've also attempted to adjust the settings (brightness, etc.) but to no avail. Help!
  • Anonymous Nov 26, 2007
    I have the same problem on the same TV. I have read online that the optical unit can be bought for less than $400.00 and replacing that fixes the problem.
  • Anonymous Mar 16, 2009
    blue dots and blue tinge on the screen
Check the optical block repair at sony's warranty website...
Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
Posted on Nov 15, 2007
SOURCE:
Dots on the middle of the screen
This is a bad light engine, call Sony see if it is on their extended warranty list.
Dec 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
Aug 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue tints w/ tini blue dots
if you see blue pixel type groups of squares or dots you may have a burnt light engine and this is common in many LCD rear projection sets; a blue screen may mean the engine became burnt--LCD rear projection sets of this kind have an optical enginge--with red,green,blue prizims--sometimes they get burned by the lamp---a photo would tell me or most techs what the problem is---the cost of a replacement engine is very expensive--some models with this problem are covered by Sony even if the set is no longer in warrant
Aug 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue ghost image on left side of screen
The Optical Block Assy would have to be replaced, same part that causes Blue Dots, not considered to be user replaceable.
Mar 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots and blue cloud. Sony 55" LCD
Sounds like magnetic interference,Do you have a speaker close to that corner?If so you need to relocate it a little farther away.
Jan 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY KF-WE50 Preojection TV
You most likely have a bad optical block. The blue dots are a pretty good indication of this. Sony has extended the warranty of some of their models to include an extension on the optical block replacement. I don't recognize your model number (Not a US model?) so you will have to check with Sony in your country to see if your set is covered. Please be sure to rate this solution. Thanks!
Nov 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Blue dots
This is a known defect and Sony will replace the optical block (the main imaging unit in the set) under Warranty - even if the set is out of warranty. Contact Sony support web site for assistance on ho to get this repaired.
Jul 11, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tiny blue dots and ablue cloud at the bottom
There is a possibility that the symptoms that you described is covered under an additional warranty, even if your set has been out of warranty for years. Sony has a site that describes this repair at no cost to the consumer: http://esupport.sony.com/perl/news-item.pl?news_id=127&mdl=KF50WE610 If this is not covered, then, the blue light panel is going out and that means it needs a light engine. Good Luck
May 12, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
1,636 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
