Question about NetGear WGR614 Router
2 x boxes ethernet connection but one gets thrown off.
Bought forward port but says password not right even though it is password that came with router
  • 192 Answers
Someone might of changed it.
Posted on Jan 04, 2009
While trying to connect to X-Box live the connection keeps failing even though my router is up and i may need to open port 3074 how do i do that?
you have to login to your wireless router and there is settings for ports. Put the port number that you want to forward.
Mar 03, 2011 | D-Link DIR-615 Wireless Router
Port fording code for digital samsung tv
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Mar 25, 2010 | NetGear DG834G Router
How to set port forwarding?
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
Click the Firewall button near the top of the page. Use the Protocol drop down box to select the protocol type of the ports you are forwarding. If you are forwarding a single port, enter that port number into the LAN port range, Left WAN port range and the Right WAN port range boxes. If you are forwarding a range of ports, enter the lowest number of that range into the LAN port range, Left WAN port range box. Then enter the highest number of that range into the Right WAN port range box. Enter the IP address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. When you are finished, click the Add button.
When you're finished, click Save near the bottom of the screen to save your changes.
And that's it! You're done! Hope this helps.
Dec 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Wont sign me into xbox live even though my router is like green
Hi, Follow the steps below to open ports on the router for XBOX:
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (XBOX1).
7. Specify the Start and the End Port as 88.
8. In the server IP Address specify the ip address of the X-box.
9. Click on 'Add' button.
10. Follow the same steps to open the port 3074 and 53 and use the name as XBOX2 and XBOX3. Click Apply.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Can't get on line
If you are using an access point or a router to get onto the internet you have to ensure that the unit has been set to accept the Xbox 360 as an authorized unit.
Jul 10, 2009 | Microsoft Xbox 360 Console
Cannot forward my port
Port Forwarding
1. Please open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
May 18, 2009 | Computers & Internet
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
Inspiron E1505 - Bad ethernet connection
right clik onmy network places chekc your lan card is enable?
if not enable it.
Nov 01, 2008 | Dell Inspiron E1505 Notebook
Ip address for xbox live
ok, firstly i hate these problems.
first things first, switch your hub off (leave for 2 mins) switch back on, this may refresh the ip address, also switch your xbox off.. then try agian.
Get back to me and let me know what happens from here.
oh also are you connecting your xbox to the pc? or directly to your broadband hub? if you can connect it directly to your hub, this should solve any problems
Aug 07, 2008 | Microsoft Xbox 360 Elite Console
NetGear WGR614 Router Logo
15 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
