Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
HELP! MY 42" PLASMA TV IS ONLY GETTING BLACK AND WHITE CHANNELS.
Last night when I turned on my tv, I only got black and white on all the channels. My DVD player still works in color, but nothing for cable. I tried unsuccessfully to go through all th menus, but nothing worked. Please help! I know its got to be some sort of setting, I just don't know which one it is. Any advice would be very much appreciated.
  • Anonymous Mar 30, 2014
    My tv broadcasts only in black and white. No settings work in trying to change color.
    President:
  • 1,284 Answers
If you are connected to a HD cale box using component cables IE (G, R & B) then check if either the Red or the Blue has come loose or unplugged as this will cause most HD sets to revert to a black and white picture.
Posted on May 04, 2007
SOURCE:
Turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv on & off but none of the other buttons work and the screen remain
tcon board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Nov 19, 2017 | Vizio VOJ370F 37 in. LCD TV
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
Random white letters in Black band, like subtitles
its ur close caption either on the tv or the cable box
Feb 27, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Wii - black and white
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
kibirag12
Jan 07, 2010 | Nintendo Wii Console
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
Just bought at Panasonic TH-50PZ80U Plasma. On some channels we are getting a static type line across the top. Black and White. Any suggestions on how to get rid of it?
have you checked in the tv menu settings. check that overscan is turned on,as this will slightly zoom in to crop the error out. hope this helps!
Dec 02, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Plasma
did the tv get bumped or ran into it sounds like the plasma tube is broken but i need more information to be sure, you could have a power problem or a remote problem try unplugging it for 5 minutes to reset it, then hold the power button down for 5 seconds and see if it comes on if not give me as much more info as possible.
Dec 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
